Is the LG 42 LT 7 HD ready? - Televison & Video
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: 42" LG Plasma HD Ready
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure.This can be due to faulty capacitors that have gone weak and resumes the value after some time when the cotlage builds up. Also there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 20, 2011
Lcd dark shadow is not fix
Sounds like a panel fault. Make it sure. Check this link. There are illustrations to plasma TV screen fault. <http://electronicshelponline.blogspot.com/>
May 23, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have a 42 "
Do you have an HD ready cable/satellite box? It sounds like your tv is displaying your games in a resolution lower than what it can handle.
May 11, 2011 | LG 42LG50 42 in. LCD HDTV
The LG 42px4dv-aa States that HD service is not available surely this tv has HD
Your TV is telling you that the network cable company or free air is not broadcasting their programs in HD. Just because they have didgital programming doesn't mean that it is HD programming.
Aug 20, 2010 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
How do i set up the HD on my panasonic HDTV
HD ready = the tv is capable of processing and displaying HD signals 1920x1080 on its screen that has a lower native resolution 1366x768
You cannot change that, the tv is build that way.
May 31, 2010 | LG 42LC2D 42 in. LCD HDTV
LG M4201C 42" will not power on.
Power supply board is dead.Must change the power supply board.Tries shopjimmy.com,Ebay.com for the part.
Jan 23, 2010 | LG M4201C-BA 42 in. HD-Ready LCD
ON CABLE I DO NOT RECEIVED FROM CHANEL 1 TO 7 AND ILLICO TELEVISION I GET EVERY CHANEL WHAT CAN I DO TO RESET TO FACTORY DEFOULT THANK YOU GERRY
have you tried re runnig set up ? that might just take care of your problem if not then you will need a mainboard replacement
Nov 28, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lg 42" plasma tv
unplug everything and replug it in,including power
May 12, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Open Questions:
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
