My Beko AA class 1100 rpm, wahes but does not spin out. is it tinme for replacement of my machine?
SOURCE: i have a Beko AA
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Posted on Nov 06, 2008
  • 1462 Answers
SOURCE: Cannot turn on my Beko
nothing special.
select program, shut door, press start button. there is a pause of few seconds before starting
Posted on Jun 25, 2008
Ajkill
  • 2035 Answers
SOURCE: beko aa washing machine does
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Sep 15, 2008
SOURCE: i need a manual for
help how do i make the machine do a quick wash
Posted on Nov 07, 2010
SOURCE: Beko A+A Class 1000 rpm
i would check the lint trap for foriegn bodies, e.g hairclips, hair bands, screws etc as these can cause the pump to stop working, be aware that water will immediately come out of the trap when you loosen it, good luck
Posted on Feb 23, 2011
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Beko WM6355W wahing machine makes a clicking noise when the drum turns, the noise gets louder and a smell of burning rubber comes when it spins
sounds like your drive belt is damaged, it may have a small section stripping of the belt and hitting something in the machine as it turns.
take off the back and check the condition and replace as needed.
Aug 29, 2014 | Beko Washing Machines
Beko stuck on spin and drain,just fill again aa class 1000rpm
Try cleaning water pump filter it's probably blocked use the filter drain hose to empty .
Jul 05, 2014 | Washing Machines
Aa class beko washing machine wont spin or start a cycle
This Beko washing machine video will help you
We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
Apr 02, 2014 | Beko Washing Machines
Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4...
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Mar 17, 2014 | Washing Machines
Instrukcja pralki beko aa class 1000rpm
unplug the machine, find a good sized pan that is very low. get a wet vac ready, then get to the pump filter there should be a drain that you would use before removing the large cap. either use the small drain "less messy but time consuming" or the large one "really quick but water all over"
Aug 15, 2013 | Watches
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
Beko aa class 1200 rpm washing machine will not drain **** on cycle
Possible that the program controller is not outputting to the drain .Check this link to repair the drain pump
Jun 28, 2012 | Washing Machines
I need a manual for a BEKO AA class 1000 RPM WMA 510W
Sep 12, 2010 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Leave power on.
Oct 19, 2008 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
