Question about Video Game Consoles & Games
Trying to install a game (medieval lords) however error message says my drivers are too old? I have an Easy note SL51 with windows Vista of which is a year old? error message comes up with 3.4.50.1;3008 as the error
    President:
  • 2,777 Answers
It is not a driver problem, but a problem with the video card itself. The video card in your system is not anywhere near powerful enough to run Medieval Lords or anything equivalent to that, any intense 3d game is not going to work on that laptop. It was definitely not designed for gaming. There is no way to upgrade or replace the video card in a laptop either unfortunately, you will either need to play it on a desktop computer, or another laptop.
So sorry about that,
Tim
Posted on Sep 15, 2010
I downloaded ML:BDE and for some reason the file StdMatDX8.fx.bin is missing and it is required for the game to run or else it wont go past the initial loading screen. i have not found a solution for this...
tHIS IS WHERE YOU WILL FIND THE MISSING FILE:
i HAVE ALREADY CHANGED IT ON MINE
C:\Program Files (x86)\Monte Cristo\Medieval Lords\Data\PLATEFORME\Data\Shader
Aug 01, 2013 | Monte Cristo Medieval Lords for Windows
Hello, I bought the game "Medieval Lords". Then, I set it in my computer successfully. But when I want to open the game, I have this message : i get an error message that reads mcINI.ccp(1599) abort o
Check you have the correct Operating system and that you have the original game. If you are running the game on a machine with Vista or Win 7 you will have problems. Check this link to see if you have the spec required.
Mar 14, 2012 | Avanquest Medieval Lords: Build, Defend,...
Medieval Lords will not start on vista ... how do I start it?
The game is most likely not compatible with Vista. First port of call should be to try to run the game in compatibility mode, to do this all you have to do is right click on the shortcut on the desktop, click on "Properties" and then goto the "Compatabilty" tab then select the "Compatability Mode" option and from the drop down menu select "Windows XP". Try to launch the game again, if this doesn't work then try re-installing the game.
May 05, 2011 | Monte Cristo Medieval Lords for Windows
Unable to run this game with vista
Hello there
Yes! things I did which together made it work...
Update your graphics card drivers
Go to the GSP / Avantsoft website and look up the game in their FAQs
There is file to Download www.gspsupport.co.uk/media/patches/Medieval_Lords.exe
1. Save the file Medieval_Lords.exe to your Desktop
2. Right click on the Medieval_Lords.exe on your desktop and left click 'Cut'
3. Go to Start ' Run, type in or Browse to C:\Program Files\Monte Cristo\Medieval Lords and click on OK
4. Please right click in this folder and left click 'Paste', this will ask you to replace the Medieval_Lords.exe , click 'Yes' .
NB If it doesn't ask you to replace it (i.e. the origional wasn't there, then look in one of the subfolders - Mine was in /Bin. Replace that and run it from there.
Jan 25, 2011 | Monte Cristo Medieval Lords for Windows
How do i run medieval lords on windows 7 ? please help im dying to play some classics
Here is how I managed to get it to work on Windows 7.
Download the patch at www.gspsupport.co.UK/media/patches/Medieval_Lords.exe
1. Save the file Medieval_Lords.exe to your desktop
3. Go to C:\Program Files\Monte Cristo\Medieval Lords\BIN
4. Right click in this folder and left click 'Paste', this will ask you to replace the Medieval_Lords.exe , click 'Yes' .
5. Go to C:\Program Files\Monte Cristo\BIN\DATA\SHADER
6. Rename the file named StdMatDX8.fx.bin from "StdMatDX8.fx.bin" to "StdMatDX8.fx"
7. Run program as administrator
Hope this helps
Jan 18, 2011 | Monte Cristo Medieval Lords for Windows
Medieval lords not running
Hello wilsonpaul74
As far as I know, there isn't a patch for Windows 7. Have you tried running it in compatibility mode? There are two ways to do this:
OPTION 1 - TROUBLESHOOT COMPATIBILITY
1. Right click on the programs shortcut, .EXE file, or installation program, and click on Troubleshoot compatibility. N.B. You will not have the Troubleshoot compatibility option available for pinned items in the Start Menu or on the Task Bar.
2. The wizard will now give you a list of options to choose from. Try each individual option, following the on-screen instructions.
If this doesn't work, you can try the following option.
OPTION 2 - THROUGH THE PROPERTIES PAGE
1. Right click on the programs shortcut, .EXE file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check the Run this program in compatibility mode for box.
5. Click on the drop-down menu arrow, and select which version of Windows the game was made for. N.B. Always pick the latest Windows version the game was made for a better chance of it running properly.
I hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | Monte Cristo Medieval Lords for Windows
Medieval Lords Installation error!
1st extract the contents of d virtual disc using POWERISO den run setup it wil install perfectly (directly instalin game by mounting image causes it 2 restart)
Jun 28, 2009 | Monte Cristo Medieval Lords for Windows
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
Video Game Consoles & Games Logo
151 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
