Question about Fuji FinePix Z10fd Digital Camera
Camera Repair The battery was placed into the digital camera the wrong way. We are now unable to get it out as it is stuck. How do we get it out??
Http://www.fujifilmusa.com/shared/bin/Z10batteryinsertionnotice.pdf
look at this link. it states that if your battery gets stuck in the camera you can send it in and they will take the battery out and send it back to you. you can also get a new battery with an identification line for proper instelation.
Posted on Jul 16, 2008
My girlfriend has done the same thing and I managed to remove the battery but the camera is not working afterwards? Any ideas what we could do?
Posted on Jun 07, 2008
    President:
  • 423 Answers
Very flat pliers called "duck-bill" needle-nose pliers. I've removed several that way, without damaging either the battery or the camera.
Posted on May 16, 2008
Sony t20 battery stuck inside
Open the battery cover, shake the Camera and HIT slowly on the hand by putting the battery side down.
Mar 06, 2012 | Sony Cyber-shot DSC-T20 Digital Camera
The camera will not power on even when I change batteries nothing happens.
Something wrong with points where the batteries attached.Clean them may be work.If not you must get it to repair center or service center.
if cleanning is solve your problem.then remember that when you going to not use your camera for a week.remove battery from it because the battery chemical get out form battery on not use it for long time and make points rusty and points are unable to connect with battery terminals.
Apr 10, 2011 | Nikon COOLPIX L20 Digital Camera
Polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 15, 2010 | Polaroid i733LP Digital Camera
I have a samsung s1070 and the lens is stuck out, it makes a whirring noise like its trying to move anda few beeps but thats it. also the screen wont come on at all its just black. do you know whats wrong...
It seems your camera Lens got stuck in open condition.
This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem, follow these steps.
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Remove and recharge / replace the battery, If the error does not clear, Keep battery battery out of the camera overnight, and try again the next day.
Else your device need service (repair)
good Luck and have a nice day.
Rating the solution is highly appreciated.
Apr 27, 2010 | Samsung S1070 Digital Camera
I have a nikon cool pix camera that doesn't turn on
When there is nothing happening, it is hard to understand what is wrong.
Do the menus cone on or anything turn on?
If the camera comes on at all, then try setting all the menus to default.
If nothing comes on, no lights, nothing, then you are stuck.
If it will not turn on at all, I would recommend selling it at a site such as Ebay for repair parts, as is. At least you can get some money back, and buy another camera.
Also you may want to consider to call Nikon and trade-in or trade-up your camera for a re-furbished unit (a re-furbished unit will have everything just as it came from the factory. The support-repair department would be the place to get the number and information.
Oct 17, 2009 | Nikon Coolpix S210 Digital Camera
My Samsung L830 Digital Camera is fully charged yet the Lens is stuck open?
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 14, 2009 | Samsung Digimax L830 Digital Camera
Ex s500 - camera lens stuck in out position.
Sounds like you have a defective motherboard, because it wasn't dropped, it is not usually a lens issue. This is a camera repair place, they specialize on small cameras like casio exilims. I've had a Canon sd750 fixed with them for the exact same problem. The website is : camera repair nyc
Jan 03, 2009 | Casio Exilim EX-S500 Digital Camera
Put rechargeable battery in the wrong way and it is stuck!
carefully remove the battery or take it to repair center... tweezers may work but you have to be careful to not damage the battery
May 21, 2008 | Olympus Stylus 720 SW Digital Camera
Unable to shut door on battery and memory card cover
some memmery cards have to click in. press in click, press in click out. or memmory card needs to be turned around.
Feb 01, 2008 | Olympus Stylus 790SW Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
136 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
