Question about HP Pavilion zd7000 Notebook
I have a HP zd7000a laptop that working find, the issue is the laptop won't turn off completely. the main power LED turn off but the volume and HHD stay on. The CPU power also stay on because it continue to generate heat but since the main power is off, there no way for the cooling fans to turn on. I disconnect all I/O's from the Mobo and reflashed the Bios still same issue. My guess is one of power relay contact got fussed together. Do anyone have a copy of the Mobo schematic to identify the defective component.
  • 23 Answers
This is a known issue with this particular model of laptop. The same issue can also cause the whole thing to drop power if you have a battery in and try to pick it up. Even further, it can give you hair-tearing problems with pretty much every ACPI function, though the OS on it seems to make a some difference (favoring linux) though this may be circumstantial. Best bet is to simulate a power failure by holding the power button with the battery out.
Posted on Sep 21, 2010
Need to fix G62 computer:will not start
"Worked in the past, doesn't work now", That's sort of the definition of a failure. Has the laptop been dropped? What does the laptop when you try to start? Do you see LED"s blink? Fan spins? HHD LED blink? Battery light on? Has the AC jack been damaged due to pulling on the cord? Did you try a cord/charger with the EXACT same power spec? Test the DC volts at the laptop cord plug with a multimeter. Reseat the Memory mods. May be a HDD failure? Post results
Feb 02, 2013 | HP Computers & Internet
Hp dv7 4065dx - power is reaching the computer (can tell by the led at the power outlet, but zero response to pressing the power button. Suggestions?
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 10, 2012 | HP Pavilion DV7-4065dx Notebook
My Hp Pavilion dv9831cl laptop quit working and won't power on, even with a full charge or plugged in. I press the start button, it lights for about a second then shuts off. Any suggestions? If I
Laptops use shared RAM, part of the main RAM is allocated as video RAM.
If the RAM is faulty then this could be the problem, get the RAM tested at your friendly computer repair shop.
Apr 06, 2012 | HP Pavilion dv9823cl Notebook
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device displays the standard green light. I tried connecting the device to...
Most of these problems are associated with an I.C. on the board that governs the HHD. Unfortunately, the chip gets pitted (overheats) on the GaAs and is ruined. The green light (LED) on the HHD will turn on as it is getting power but the main chip that controls the HHD no longer works thus rendering the HHD inoperative.
Bottom line, get a new external drive. Should you get the same model or something similar to what type of electronic hardware you have, you can remove the new HHD and put your old HHD in its place and you will see that all of your data is still intact.
Apr 12, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
On my hp 6710b running windows 7, im trying to get wirless to work and it tells me it is not on and that I have to turn on switch on front or side , or use function keys . I have looked everywhere and I...
Here you go. . .(#18 is the button location)
439c6ce.gif 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone
4. RJ-11/modem port
5. Optical drive
6. Media Card Reader
7. 2 USB 2.0 ports
8. HP Fingerprint Sensor
9. Integrated stereo speakers
10. Touchpad with scroll zone
11. Touchpad buttons
12. Hard drive activity / HP 3D DriveGuard LED
13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option)
Aug 26, 2010 | HP Smart Buy Notebook
Zd7000 mobo not powering up
I've found this particular issue to be common with the zd7000 and zd7000a (the 'a' model especially. For whatever reason, the battery tends not to make good contact no matter what you do, and if the motherboard sees you have one, it uses it. This would be fine, but if the battery loses contact, AC power doesn't come up fast enough.
Sadly, the only realistic solution for the lay-user is to place the computer on a flat, steady surface, preferably something that assists ventilation, and keeps the battery stable and as immobile as possible.. Once you stop thinking of it as a laptop and start thinking of it as a portable computer, it tends to make living with it much easier.
Nov 24, 2009 | HP Pavilion zd7000 Notebook
On a hp compaq 6710b where/ how do i switch wifi on?
The wireless button should be located on the top left part of your laptop. It will be the 3rd button from the left.
11bffdfe321d68aa11aa600332bfe03c.png e8721ff914fb66ee83d789398c8a2a31.png e8721ff914fb66ee83d789398c8a2a31.png d44fad740e4749adb4fe5f87725dd44f.png 1. Volume mute button with LED indicator
3. Integrated microphone 4. RJ-11/modem port
5. Optical drive 6. Media Card Reader 7. 2 USB 2.0 ports 8. HP Fingerprint Sensor 9. Integrated stereo speakers 10. Touchpad with scroll zone 11. Touchpad Buttons 12. Hard drive activity / HP 3D DriveGuard LED 13. Battery charging LED
Jul 11, 2009 | HP Smart Buy Notebook
Compaq evo n610c
According to the HP website, the power button is #3 on the following diagram... http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Jun 19, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
74 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
