Question about Maytag SDE3606A Electric Dryer
Drum keeps rubbing on blower housing. - Maytag SDE3606A Electric Dryer
    Master:
    Sergeant:
  • 449 Answers
Have the bearings on the drum checked
Posted on Sep 15, 2010
Maytag Performa pdet920ayw has a horrible squeal. The drum is metal to metal with the blower housing
It seems like defective slider , ,check out each carefully and replace if needed such as roller, front seal or rear seal or loose blower fan blade assembly
Feb 26, 2015 | Maytag Dryers
Frigidaire dryer blower fan keeps getting stuck.
Since you didn't leave a model number, I will have to give you a generic answer, instead of one with a part number of the most likely replacement part. Normlly the problem you discribe is a result of the blower motor bearing wearing out and letting the fan blades rub against the housing. And since the bearing is internal to the motor, you have to replace the entire motor.
Dec 30, 2011 | Frigidaire Dryers
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 21, 2011 | Maytag Dryers
Loud Bank noise when Creda Vent dryer is in motion.
Unplug or disconnect power before disassembling the dryer.
Most likely the noise is coming from 1 of the 2 drum support rollers or the shaft. It also could be the blower wheel loose or rubbing the blower housing. There is also a belt and belt idler assembly that could be making the noise.
Jan 17, 2011 | Hotpoint Dryers
1999 siverado 1500. heater fan works on all five speeds but i have low air flow.having trobble keeping windows defrosted. could i be a blendgate.
It sure could be a blend gate. I have had some problems with the blower motor fans rubbing on the inside of the hvac housing too. When this happens the air will not flow to the hvac housing and then out to the vents. It is an easy check. Just pull out your blower motor and check the housing for any rubbing marks on the housing or the fan. Past that then you need to further check the blend doors or possible blockage of the heater core or A/C evaporator. Hope this helps.
Dec 31, 2010 | 1999 Chevrolet Silverado 1500
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Mar 07, 2009 | GE Dryers
Maytag SDE3606A Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
