Question about Cisco Linksys WET610N WirelessN Bridge Network Bridges
Trying to run the setup cd for the wet610N on a WGR614v7 router and getting error 107 after it tries to find the device.
  • gm_worboys Sep 15, 2010
    I am trying to be savvy but not having any luck :) I tried giving the ip address that I could find on the attached devices section on my netgear router and I have one that says it works. I have the bridge on port 4 so when I type that ip address xxx.xx.1.4 in it cannot find it. Perhaps my netgear is not compatible. I have the WGR614v7.
    Scholar:
  • 91 Answers
Setting this up would be easy if you do it manualy. Just wire the bridge into your router, access the setup page of your router, go to the DHCP client table and take note of the ip address of the bridge.
Open you internet browser then type the ip address of the bridge into your address bar.
You'll be asked for a UN
Posted on Sep 15, 2010
I get an error 323 during setup
Are you trying to run the CD to setup your router?
I will suggest you to install your router manually.
It is very easy.
Connect one computer to the router. Open the setup page of the router and change the settings manually.
See Linksys router setup.
Jan 09, 2012 | Linksys WRT54G2 Wireless Router
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
Hi, I'm getting an Error 109 (Setup wizard cannot detect your device) error when I try to set up my WET610N and my Verizon MI424WR router. It previously worked ok with a Linsys router at a different...
There is a reset button on the back of the unit, I think next to the power connection, hold it in for 10 seconds.Do not confuse this with the WPS button on the front
Have you configured the WET610N on static ip or DHCP....?
Reset the WET610N..Connect the computer to the WET...Open the setup page of WET and re-configure all the settings again.Once done,power cycle the router and bridge.Now,check.
Sep 22, 2017 | Linksys WET610N WirelessN Bridge...
ERROR 102
Make sure wet610n adapters have the same wireless settings with your 2 wire modem and the wireless link status of the bridge shows connected. That's how wet610n communicate with wireless routers/modem. If wireless settings do not match they will talk with each other wirelessly.
Jan 04, 2011 | Linksys WET610N WirelessN Bridge...
Cannot get 2wire router to connect to wet610n adapters. Directv (who sent me this) cannot help. I need to know what to do to fix this issue. Keep getting error messages from 102 to 109,
Oct 20, 2010 | Linksys WET610N WirelessN Bridge...
I have tried to connect my linksys wet610n to my netgear wpn 824
You need to make sure to configure both WPN824 and WET610n with same wireless settings.
Let me know if still can not achieve connection between the two devices after configuring with same security settings.
Feb 16, 2010 | Linksys WET610N Pre-802.11n Wireless...
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Linksys Model WRG2 - Can't run installation CD
If the setup CD is not working , you can manually configure the router by accessing its setup page if you're not familiar on how to do that I will advice you to contact Linksys tech support and let one of their tech wlak you through on how to configure the router manually since your router is new and tech support is free and open 24/7 better call them and they will walk you through in manually configuring this router , this is the number 800-3267114....
Hope that helps..........
Sep 13, 2008 | Linksys Computers & Internet
Cisco Linksys WET610N WirelessN Bridge Network Bridges Logo
467 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
