Question about Hamilton Beach Kitchen Appliances - Others
I have a 4 slice toaster.the left 2 slice slots will not stay down.the heating elements work and everything else works well,how do I fix the hold feature of the toaster?
  • Hamilton Beach Master
  • 1,711 Answers
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
Posted on Sep 15, 2010
Left side does not drop toast down, elements work.
I had to take my toaster outside and clean out the sidees of each slot. There was debris baked on and it had the wire frame stuck. Once I cleaned, scraped and emptied out the junk, the toaster works fine.
Jan 25, 2011 | Breville BTA840XL 4-Slice Toaster
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
Problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
Apr 25, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 01, 2008 | Kitchen Appliances - Others
Breville classique toaster
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
May 12, 2008 | Breville CT20 Retro Classic 2-Slice...
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Kitchen Appliances - Others Logo
554 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
