Its a trouble a firmware/android issue. Try charging it with an adapter that doesnt have a plugable cable USB/micro usb that gets in in the adapter, but with an adapter that ghas micro usb directly.
Have the same issue with my last phone and this fixed it. Next time charge your phone before its flat/completely empty
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Hi, It denotes that USB charging is not supported by uour mobile phone. If you are using the same socket in your mobile phone for charging whcih you are using for connecting your mobile to computer then there may be USB charging option available for your phone. If you are having separate charging Jack in your phone. Then USB charging option may not be possible. Please refer your mobile phone user manual to check whether the USB charging option is available or not.
Does not want to charge with USB
wats the default securitycode of samsung sgh-c417?
