Question about Calculated Industries Pipe Trades Pro 4095 Advanced Pipe Trades Math Calculator
My pipe trades pro when solving a rolling offset only gives me 0.0 degrees
Hi jlight49,
Your Pipe Trades Pro calculator from Calculated Industries comes with FREE technical support:
Live chat - http://messenger.providesupport.com/messenger/calculated.html?ps_s=PJ2Ks9f4GXh8
Email - techsup@calculated.com
Phone - 1-800-854-8075
It is hard to tell from the description of your issue, but when working with a rolling offset, the [Angle] will show 0.00. All the rolling offset outputs are accessed through the second function of [Travel] which is labeled as [Roll].
The key sequence is:
-enter your rise into [Offset]
-enter your advance into [Run]
-enter your roll into [Roll] by pressing [Conv] [Travel]
-press [Travel] repeatedly to see the rolling offset outputs, starting with Length, followed by Fitting Degree, etc.
Contact technical support and they will help you out!
Thanks.
Posted on Sep 16, 2010
What is the rolling offset using 45 deg bends
The formula for 45 degree bends is offset" x 1.414 equals the travel distance in inches. Example: to calculate the offset of a line 6 1/4", in other words move the line over. Turm 1/4 into decimal form (1 divided by 4=.25). Calculate: (6.25 x 1.414= 8.8375). To convert the decimal form of .8375 to a fraction multiply it by 16 (16/16=1") example: .8375 x 16=13.4 , 13 is the numerator, 16 is the denominator which gives you a fraction of 13/16". That gives you your travel distance center to center of a 6 1/4" offset= 8 13/16" travel distance. For accuracy in your measurement, you must subtract the fitting allowance (how much space the fittings take up in the measurement) from your overall travel distance. It sounds like a lot of steps, but using this formula gives you dead on accuracy in pipe fitting. If you know your travel distance and wish to find the offset, multiply x .707. Hope this helps.
Feb 12, 2015 | Plumbing
If I have a shaft that is 49.5" long and it is offset .150" side to side what degree is it offset
A total offset of 0.150" is about 0.35 degrees on a length of 49.5". The impact that something being this loose has on a rotating part adds up quickly.
If I knew more about the part & assembly I could give you some advice. You could sleeve the bore or Grind, Chrome & Grind the journals to the proper size, If the 0.150" is from journal damage. If the offset is due to bending you might have to be a little more creative. mpro at cox dot net
Oct 30, 2013 | CRL Long Shaft Windshield Cut Out Wire...
What is the timing setting for 2000 chevrolet pick up 5.7 L
You cannot adjust ignition timing on the 5.7 liter V8 vortec engine. This system uses the distributor as a camshaft position sensor. You can loosen the distributor and rotate it, but it adjusts something called Camshaft Retard Offset. This can only be checked and adjusted using a scan tool that can read the cam retard offset parameter. Otherwise, you\'re flying blind. If you have a scan tool that can read it, the retard offset should be set to 0 degrees with the engine fully warmed up and running at 1000 rpm. If you cannot adjust it to 0 degrees, the distributor may be off a tooth or two, and will need to be correctly re-timed to the engine.
Aug 17, 2013 | 1996 GMC Sierra
Hello i have a 1993 chevrolet silverado 1500 and i jus replaced the fuel pump and the distributor and now it wont stay running and it back fires can u tell wat might be wrong
Hello theman022002,
Your description would indicate that the timing is off. Possibly when you installed the new distributor you were off a tooth or two. Turning the distributor Will Not adjust the timing.
You will need to reinstall the distributor with every thing set to top dead center, then follow the steps below to set the proper cam retard offset.
Good Luck.
Ignition Timing: Adjustments
TEST PROCEDURE
The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
1. With the ignition OFF, connect the scan tool.
2. Start the engine. Allow the engine to idle until the engine reaches normal operating temperature.
IMPORTANT: Cam retard Offset reading will not be accurate below 1,000 RPM.
3. Increase engine speed to 1,000 RPM while performing the following steps.
4. Use the scan tool in order to monitor the Cam retard Offset.
5. If the Cam retard indicates a value of 0 degrees, the distributor is properly adjusted.
6. If the Cam retard does not indicate 0 degrees, the distributor must be adjusted.
ADJUSTING PROCEDURE
1. With the engine OFF, slightly loosen the distributor hold down bolt.
2. Start the engine and raise the engine speed to 1,000 RPM.
3. Use the scan tool in order to monitor the Cam retard Offset.
4. Rotate the distributor as follows:
a. To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
b. To compensate for a positive reading, rotate the distributor in the clockwise direction.
5. Repeat step 4 until 0 degrees is obtained.
6. Turn OFF the ignition.
NOTE: Refer to Fastener Notice in Cautions and Notices.
7. Tighten the distributor hold-down bolt to 3 N.M. (25 lb ft).
8. Start the engine.
9. Raise the engine speed to 1,000 RPM and with the scan tool view the Camshaft retard Offset to verify 0 degrees has been maintained.
Regards,
netvan
Apr 10, 2011 | 1999 Chevrolet Silverado 1500
How to set timing on 1998 gmc sierra
The v-8's timing is supposed to be 0 degrees plus or minus 2 degrees and is only adjustable if you have a scanner. A timing light does not work on them.
These engines can be "timed" in the way you are used too.
The distibutor housing holds the cam sensor, The PCM calculates the timing by measuring the crank signal and the cam signal.
What you are seting by turning the distibutor housing is the correlation between the 2 sensors. On the V-6 model, the housing holddown bracket is fixed to the housing so if you return the rotor to the proper position when reinstalling the housing, the engine should be at the correct cam sensor position setting.they did not fix the holddown bracket to the V-8 models, it would have saved a lot of headaches.
To set the correlation between the 2, you will need a scan tool that can read camshaft position offset. With the engine RPM over 1200 adjust the offset too 0 degrees.
TEST PROCEDURE
With the ignition OFF, install a scan tool to the DLC.
Start the engine and bring to normal operating temperature. IMPORTANT: Cam ****** Offset reading will not be accurate below 1000 RPM.
Increase engine speed to 1000 RPM.
Monitor the Cam ****** Offset.
If the Cam ****** indicates a value of 0°+/-2°, the distributor is properly adjusted.
If the Cam ****** does not indicate 0°+/-2°, the distributor must be adjusted.
ADJUSTING PROCEDURE
With the engine OFF, slightly loosen the distributor hold down bolt. IMPORTANT: Cam ****** Offset reading will not be accurate below 1000 RPM.
Start the engine and raise engine speed to 1000 RPM.
Using a scan tool monitor Cam ****** Offset.
4.1. To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
4.2. To compensate for a positive reading, rotate the distributor in the clockwise direction.
Repeat step 4 until 0°+/-2°, is obtained.
Turn the ignition OFF.
Tighten the distributor hold-down bolt to 3 Nm (25 lb. ft.).
Start the engine, raise engine speed to 1000 RPM and recheck Camshaft ****** Offset.
Thank you for using fixya and good luck.
May 09, 2010 | 1998 GMC Sierra
How do you make a 45 degree pipe elbow into a 30 degree
It is not advised to adjust connections.
I suggest you buy a fitting that is at 30 degrees, or one that is adjustable between 0 and 90 degrees.
These are available for waste pipes.
Failing that, PS waste pipe can be bent with a hot-air gun, and new connections made further away - but I'd go with getting the right connection.
Mar 04, 2010 | Plumbing
I have a code 1345 set each start cycle. I can clear the code when running. I have not put it through the hoops. I believe it will stay clleared untill the next start cycle.
Ok it appears you have a cmp corelation offset code. If you have a scanner you can check the timing if not you will need one. This code usually sets when you have more than 16 degrees offset. the specification is 0 degrees CMP ****** +- 2 degrees. It is also possible you have worn teeth on the distributor (sharp edges) this will cause it to be out of time.
I hope this helps.
Roy
Nov 06, 2009 | 1998 GMC Sierra
Offset of verticle stove pipe between stoveand chimney
use single wall pipe in the heated area.
Aug 19, 2008 | Grilling
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
May 16, 2008 | Microsoft Excel for PC
Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Mar 15, 2008 | Radio Shack Pro-96 Scanner
Calculated Industries Pipe Trades Pro 4095 Advanced Pipe Trades Math Calculator Logo
203 people viewed this question
Top Calculated Industries Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Calculated Industries Measuring Tool and Sensor Expert? Answer questions, earn points and help others
