Hi. i am trying to assemble an HP xw4300 workstation. i recently bought from ebay a refurbished motherboard. everything works and the unit started up fine. but at 30% of copying files windows xp sp2, the computer hangs. I switched off the unit manually from the power switch. the unit did not boot upon restarts. instead i hear and see 5 short beeps and red flash simultaneously. what did go wrong? is the unit salvageable? during the beeps and flash, the system fan, cpu fan, and psu fan are spinning. i removed rams, video card, hdd but still the beeps and flash persist. please help
  • Computers & ... Master
  • 923 Answers
Was the hard drive were using new, or used? It sounds to me like it had a virus on it. I've seen that scenario before! Some malware (in particular, TDL4 and variations of it), create hidden partitions that most antivirus products never find! But all the drive has to do to get reinfected is to pass over that area on the hard disk. But if your hard disk was brand new, then I am very likely "barking up the wrong tree," if you know what I mean!
Posted on Apr 19, 2017
SOURCE: Motherboard ABIT KN8
I just lost my fourth KN8 motherboard and it always seems to take out the power supply unfortuneately. One I returned for the 3 year warranty and as a replacement it worked less than a month. These were on 3 different machines(cases and power supplies of various suppliers) so the mother board is the fault.
Will be hesitant to use ASUS boards again even though this may be isolated to this board only.
Posted on Feb 05, 2008
  • 1554 Answers
SOURCE: New computer won't POST
have you tried different memory as no matter what the board says they don't like some memory .
also take the board out of the case and connect pwr supply.
cpu and fan ,video card , and 1 memory stick
no cables ,keyboard ,mouse or drives connected.
this is called bread boarding.
reset the bios jumper, then put jumper back.
and power up.
Posted on Mar 31, 2008
  • 781 Answers
SOURCE: Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Posted on Aug 16, 2008
  • 1179 Answers
SOURCE: nFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 27, 2008
  • 644 Answers
SOURCE: Packard Bell IMedia 5055: GA-8SIML will not post
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Posted on Feb 04, 2010
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
I used a hp restore plus cd on my hp xw4300 workstation and i dont have the second disk it is asking for.i need to restore my tower .all i can get into is hewlett-packard setup their a way i...
A HP restore CD is unique to each model HP computer, You cannot us a HP restore CD on any computer.
You need to get the correct HP restore CD for your model HP computer from the HP WEB site.
Dec 01, 2012 | Computers & Internet
Will xw4300 accept compaq S6200cl hard drive
HP XW4300 Workstation Desktop PC specs,
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
Product Information > Product Specifications > Product Specifications,
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
HP XW4300 Workstation motherboard example,
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Nov 05, 2012 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
HP NC6230 No video
You need a CPU and RAM to get the motherboard running.
On-board video use part of the main RAM for video RAM.
Check the RAM, is it the correct type for this motherboard?
If all checks out then the motherboard maybe faulty.
Mar 04, 2012 | HP Compaq nc6230 Notebook
Good afternoon. re: HP xw4300. The microphone socket on the front panel has a cable that ends in a connector which is not attached to anything. The connector has 12 connections, but I can find...
Hi Tony,
Its the Audio Connector. and it is supposed to be connected at the position marked as 1.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 17, 2011 | HP xw4300 PC Desktop
I have a seagate barrracuda hard drive model ST3160023A which came out of a working bootable Compaq Presario 6000. I would like to use this hard drive in a newer workstation HP xw4300. I being told this...
i have not heard of anything like that. the only thing that would make a difference is the connection. yours is sata i believe. here is a link that tells everything about that drive.
i do believe you would have to wipe the drive and format it and treat it like a brand new drive when you install it.
Feb 06, 2011 | Seagate Internal Hard Drives: ST3160023A...
XW4300 Sound Card problem, only working in Windows MP
Most online audio makes use of Adobe Flash, did you check that?
Best is to download and install the latest version of Flash to make sure.
Installing the latest version of DirectX for Windows XP can also help (9.0c).
Please also check for further suggestions about fixing sound problems in Windows XP.
Apr 01, 2009 | HP Workstation xw4300 Pentium-4 650 3.4GHz...
Manual needed for Hp 383620-001 XW4300 System board
You will find everything in this link
Please rate this post as solved.
Do not hesitate to ask another question.
Thank you
Aug 20, 2008 | Computers & Internet
How to assemble the computer
if u want assembled a new machine first of all attach motherboard with the cabinet as per the instruction after that
Jul 28, 2008 | Compaq Refurbished 280WATT POWER SUPPLY...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
