Question about HP Computers & Internet
My DVD drive is not recognized on my laptop? how do i reinstall
  • 734 Answers
Try this Microsoft automated FixIt tool. It's worked for me many times.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Best Regards,
Marcus
Posted on Sep 15, 2010
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
I wanted to fromat then reinstall for 255E model. But it cannot recognize my USB DVD Drive
Have you checked to see if it is recognizing the dvd drive in the bios? If so it may just be the boot sequence that you need to change. If not try unplugging, replugging and rebooting.
Aug 28, 2011 | Acer Computers & Internet
My daughter dropped my laptop on my Cd/dvd player
probably came loose and needs unpluging and replugging
Apr 26, 2010 | Acer Extensa 5420-5687 Notebook
Can't use cd/dvd player - computer doesn't recognize it
try to boot the computer using cd. like you trying to install windows. if it read the cd to get into the windows setup, then cd drive is good.
1st make sure you set the option boot from cd first in the bios.
2nd place a windows setup into the drive.
3rd save and exit the bios.
4th if it ask you to press any key to enter setup then the cd drive is good.
maybe u have a windows problem, try to reinstall windows, that the easy way.
Aug 28, 2009 | HP Pavilion dv2000t Notebook
Windows 7 Beta has deleted my DVD drive.
Do this to be sure that your dvd drive is still being recognized by your laptop. Turn on your laptop and go into your BIOS. Once your in there look to see if its listed in there. If it is then you know for sure that the laptop is recognizing it properly and that its a windows 7 issue. If the dvd is not recognized in the BIOS then what you need to do is with the power off. Take out the dvd drive completely and reseat it back into its slot. Then turn the laptop on, go back into the BIOS and see if its recognized in the BIOS now. If its still not recognized in the BIOS then that means the dvd drive is bad and would need to be replaced. As far as drivers are concerned and that you verified that the dvd drive is recongized in the BIOS, you may not be able to get drivers because windows 7 is not out for the public yet and drivers may not be available, you can always check the manufacuter of your dvd drive and go to there website to get drivers but since windows 7 is not out yet to the public your chances of getting a driver for it are slim.
Jun 04, 2009 | Gateway Computers & Internet
Laptop not recognizing drive...
sir
you should reinstall the drivers for your DVD ROM . It should be given to you when you have purchased it.
if not go here and download
Mar 08, 2009 | LG SecurDisc 20x External Double-Layer DVD...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
I reformatted the hard drive and reinstalled Windows Xp on my Sony N-TXN15p laptop. Now my CD/DVD drive isn't being recognized. What can I do?
You will need the drivers for the drive. When you look at the devices in device manager (devmgmt.msc) do you see any drives under DVD/CD-ROM drives?
Mar 06, 2009 | Sony VAIO VGN-TXN15P/B Notebook
Dell laptop does not recogize cd/dvd combo dribe
1.Try to update BIOS Firmware
2.Reinstall OS and latest Drivers
Dec 14, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dvd drive is not recognized , toshiba satellite a75
Hi solorzano581,
I think most likely the problem is with your Windows OS, since you already tried a known good drive and the problem is still there. But before you do a reinstall of the OS, I suggest that you try the troubleshooting steps from this Microsoft KB: http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060 . Especially the one with deleting the upper filters and lower filters in the registry which works almost 100% of the time.
Check to see if you can still use the drive outside of Windows, by booting from the Windows XP or Vista disc. If you can't boot using the reinstall CD, then most likely the problem would be your hardware (motherboard controller perhaps?) If this is what's happening I suggest that you run your laptop's diagnostics software to verify the hardware functionality.
If all else fails, contact your computer manuacturer for additional hardware/software troubleshooting.
Hope this helps!
Peace! :)
Oct 20, 2008 | Toshiba Satellite A35-S159 Notebook
Computers & Internet Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
