Mac hd 320gb os-10.6.4(extended-journeled)is very slow. have used 245gb . how can i get back to normal speed. thanks, jim
  • 1 more comment
  • James Fox Sep 15, 2010
    i would like this to be my primary problem for now, thanks, jim
    yes, thanks
  • Jack Qusam Sep 04, 2012
    I am trying an all-in-one Mac speed up software and it helps resolve all issues in just a few clicks. Learn more:http://www.howtospeedupmac.com/
    Brigadier General:
  • 3,917 Answers
Please check this link and rea the discussions in the forum which is related to your issue:-
http://www.mac-forums.com/forums/os-x-operating-system/174143-how-can-i-clean-my-mac-so-moves-faster.html
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Sep 15, 2010
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
Can I download Simpletech pininfarina 320gb drivers on Macbook Air
On a Mac you generally have all the drivers you need built in. Would be very rare these days to download a special driver. Any drive plugged in to the USB port usually shows up.
Perhaps the drive needs formatting first. Often external drives are pre formatted for PC.
First...Open Drive Utility in Applications / Utilities Folder
Then Plug External Drive in.
It should show up in Left Column of DU Window
Use Drive Utility to format & test the drive.
Use the Mac OS Extended (Journled) if using with Mac files or FAT 32 if swapping data from PC to Mac & back.
Good Luck
Oct 18, 2014 | SimpleTech Computers & Internet
Defragment/clean-up external HD
Hello Anonymous
Make sure you have backed up all the files you need to keep.
Store them on the computer if you have the space... until you put them back on the clean Hard Drive.
Your drive would be seven years old now. So... it would be a wise move to do a security type format to test the drives integrity before you loose your backups. Many Drives don't last seven years...
320GB is also pretty small these days. Suggest you use the old drive for eg. "Movies" and buy a new Hard Drive for your Backups as this drive may fail at any time.
Murphy's Law says that will be when you need it the most!
A 3.5 inch Drive (uses 5v&12v) and is more robust & faster than your 2.5" pocket type drives that run on 5 volts only. Also, look for a USB 3 or FireWire Port connector as these will ensure compatibility & speed on future computers. USB 1&2 are slow on large files.
DeFragging only shuffles the empty space around. Lining it up sequentially so that it's faster at accessing the data.
Re Formatting wipes the directory off the drive making it appear that you have a new clean drive. Previous files then get overwritten.
Do a security erase if you want to clean all data from the drive & test the drive for faults. This will return all available space available to you as an empty drive.
On a Mac, use Disk Utility. Choose Fat32 to allow interchangeability with Mac <> PC or "Mac OS Extended (Journaled)" for Mac Bootable Disks.
On a PC use Disk Management for a quick format to Fat32 or NTFS for Windows Boot. Or See Here for full details:
http://pcsupport.about.com/od/tipstricks/f/format-hard-drive.htm
Drives are so inexpensive these days. You can pick up a 1Terrabyte drive for $99 here. Format & test the drive before putting it to use on your computer. This will be one of the few times you will get to test & experiment with the drive before you put your data on it.
You can always use a USB Memory Stick as a pretend Hard Drive to experiment with & test the formatting procedure. They use the same Partition & Format utilities as a regular Hard Drive.
Cheers
Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 06, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My portable drive is not recognised many times
The format of your drive is probably not correct. If data is not stored on your hard-drive, format it to NTFS if on Windows, or Mac OS Extended (Journaled) if on a Mac. If there is data, back it up to a computer that can read it and then format the drive.
May 31, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
I have a mac. how do i get the 320 to work? i already have stuff backed up on it from my old computer which was windows.
Your Mac can't recognize the 320 because it's formatted as NTFS and Mac uses Mac OS Extended (Journaled) format. You need to install one or two apps on the Mac; Crossover or Parallels, and then install the Windows software on the Mac you need to read and use the files.
At that point, some files which share file types in Windows and Mac could be transfered (jpeg, mp3-4, etc.)
You'll learn maybe more than you wanted to,
Good Luck,
Marcus
Sep 15, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My powerbook G4 is working very slow Hardware Overview: Machine Name: PowerBook G4 12" Machine Model: PowerBook6,8 CPU Type: PowerPC G4 (1.5) Number Of CPUs: 1 CPU Speed: 1.5 GHz L2 Cache (per...
Well, there are a lot of reasons that can consequently cause the issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try the all-in-one Mac speed up software as it can help resolve all issues in just a few clicks.
May 04, 2010 | Apple PowerBook G4 Mac Notebook
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Slow startup and overall operation
Well, there are a variety of reasons that can consequently drag down the performance of your Mac. Meanwhile, there are certain ways through which you can considerably speed up your Mac machine. For example, you can reset the browser settings to regularly clear useless caches and history, get rid of all unwanted widgets from the dashboard through the Dashboard control panel, remove unnecessary applications, find out & delete those duplicated files. However, if you prefer a more efficient way to speed up your Mac, try the following all-in-one Mac speedup tool as it can help resolve all issues in just a few clicks.
Read more from: http://www.howtospeedupmac.com/
Hope this helps!
Apr 13, 2009 | Apple iMac G4 Desktop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
