Question about GE GSL25JFPBS Side by Side Refrigerator
Water wont dispence . have to shut freezer off and open door for 30 min. to get it to work
I use a hair dryer to thaw it out. Just aim the hair dryer around right side and bottom of the water dispenser for about 5 to 15 minutes.
Posted on Sep 18, 2010
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water wont dispense light dims
If your light dims your unit is working you probably have frosen water clogging you tuber just inside the freezer door
Use a hair dryer it may take you 30 min or more. Check under the front kick plate below the freezer door and see if there is a check valve or grabe the line and activate the water. feel if there is force there.
Apr 22, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Nov 27, 2008 | GE Refrigerators
Samsung american fridge freezer ice tray is stuck at angle and wont make new ice
I had the same problem, It's because you have tried to press the button with the door open to get the tray to rotate. If your pressing the overide button with the door open you need to pretend the door is shut by pressing the hinge thing (it's half way down the left hand side of the freezer, turns the light out aswell) or else it the tray tries to do a 360 whitch it can't. You have to force it back to central. I can get mine to work and water is coming out of the water shute but no water is going into my ice tray to make the ice. I put some normal ice in and it dispences ok but it just wont make it's own. Anyone got any ideas ?
Oct 25, 2008 | Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
GE GSL25JFPBS Side by Side Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
