Question about Canon PIXMA MP530 All-In-One InkJet Printer
My printer shows head alignment problem, what to do? it prints top half of the line only
    Genius:
  • 1,044 Answers
Go to Control Panel. Click on Printers & Faxes. Right Click on your Printer's icon. Click Properties on the drop down menu. Click Maintenance Tab. Select Print head Alignment. Carry out the instructions displayed. A print test page will be printed after the alignment has been done. Check the printed matter with the sample page. If not OK again carry out the process till you get a clear printed page.
Posted on Sep 15, 2010
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
When I print tables, the lines come out crooked. Any idea what the problem could be?
do the print head alignment... to do this..first switch OFF the printer and then load paper, press the Pause button while switching ON the printer.. the printer will then print the instruction for you to align the print head. Just follow the instruction and select the best printed line.
If when you print text or line, and you notice there is some part missing, this show that you print head have broken pins. If this happen, you will have to replace the print head.
Jun 14, 2010 | Epson LQ 680 Matrix Printer
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
Aligning print head doesn't fix the printing
You only need to clean the encoder strip. The plastic strip behind the carriage assembly. Wipe it gently with a damp Q-tip and the double lines will go away.
Jul 20, 2009 | Canon PIXMA MX310 All-In-One Printer
TOP MARGINS
I have a HP Deskjet D1470 and wish to align the print heads
May 05, 2008 | Office Equipment & Supplies
Nozzle check wrong, but no clogged printhead
on an i960 canon the magenta does not come through/thank you,Leo
Feb 17, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
244 people viewed this question
old marine
old marine
