My printer epson stylus cx5500 says service required.....
Basti
  • 1447 Answers
SOURCE: Epson Stylus CX5500 resetting; notification of need for servicing keeps popping up
Hi-
Yep chances are there is a problem with the hardware itself. On the computer where you have it connected directly, did you get an error message? if you did then it talks about part at the end of service life then that is the inkpad you are having a problem with, but if there is no error message that popped up on the computer then there might be a problem on the mainboard, call epson so that they can give you a discount if you are going to buy one from them again. you can reach them at 562-276-4382. Thanks for using Fixya!
Posted on Jun 21, 2008
  • 3 Answers
SOURCE: my printer epson stylus T10
you can also use the SSC service utility
Posted on Mar 22, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
SOURCE: service required for EPSON STYLUS R230
red light bhoth blinking
Posted on Dec 28, 2009
cns assoc
  • 677 Answers
SOURCE: epson stylus T10 printer stopped working
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Mar 19, 2010
I changed the cartridges in my epson cx5500 but its still not working
Problem with the Epson Stylus CX5000 InkJet Photo Printer
i changed the cartridges in my epson cx5500 but its still not working
Hi Good day!! is there any error message? or Blinking orange/red in your printer? if no errors try to restart your printer spooler.
Follow this method:
1. Turn off your printer and then trun it back on see your printer status if it is online and ready.
2. Click "Start"
3. Click "Setting"
4. Click "Control Panel"
5. Choose "Performance and Maintenance"
6. Click "Administrative tools"
7. Click "Services" now you should be on Services box
8. in Services box find "Print Spooler" Click it and then click "stop" at the upper left of the box and then start it again.. hope it works now..
Oct 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I am trying to find the software of Epson stylus CX5500 printer
hi bunrany
if you go to Epson Driver Download you will be able to download the drivers you need .
riz.
Jan 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Installation of cx5500 epson no installatin cd
You can get the software for the Epson Stylus CX5500 from here:
http://tech.epson.com.au/downloads/category.asp?id=styluscx5500&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2745207&sCategory1=Multi_Functional
Just choose your operating system and press Search, then Continue on the next page.
Fixya!
Chris (ziraffa)
Jan 16, 2009 | Linksys WPSM54G Print Server
Epson cx5500
I need some software for resetting epson cx 5500, please ?
Jan 07, 2008 | Epson Stylus Multifunction Inkjet Printer/...
220 people viewed this question
k24674
