Question about Garmin NUVI 710 Car GPS Receiver
AnsI have upgraded my Bluetooth firmware for my Nuvi 710. No it is just stuck at 48%
SOURCE: Bluetooth Connectivity between Nuvi 710 and Blackberry Bold 9000
get the firmware update from the Garmin Updater. It fixes the connectivity issue with the BB 9000
Posted on Jun 15, 2009
SOURCE: nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Posted on Aug 15, 2009
pabloloco
  • 2335 Answers
SOURCE: Garmin Nuvi fails to work after firmware update
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Posted on Mar 18, 2010
pabloloco
  • 2335 Answers
SOURCE: Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Posted on Apr 19, 2010
fathitkf
  • 1871 Answers
SOURCE: garmin nuvi 760 ...updating bluetooth firmware
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
After that you can try again with updating .
PLEASE DON'T FORGET TO RATE !
Posted on Apr 20, 2010
Updates for the nuvi 710
  • Try to login to their website and then checked if there is a firmware update for your GPS device and for map updates its also on there website. For map updates there will be a payment for the map but for the firmware that will be for free.
If you have questions feel free to reply to this solution. Thank you.
Feb 14, 2011 | Garmin NUVI 710 Car GPS Receiver
My garmin 765T does not have the bluetooth icon under settings any more. How do i pair up my blackberry to the garmin
This is usually caused by a corruption in the bluetooth firmware.
First make sure you have the file "006B055301.GCD" within the "Garmin/Remote SW" folder. You will need to connect the Nuvi to a PC with the USB cable to confirm the file is there.
If it isn't there you will need to download it and put it there. A copy of v3.4 can be found here:
http://www.shcbc.net/gps/006B055301.GCD
Next, SAFELY REMOVE your Nuvi from windows before removing the data cable.
1. Go to the screen that shows the map and where your current position is.
2. Press the icon in the lower left-hand corner that shows your arrival time.
3. You will now come to a dashboard screen. Press and hold your finger on the odometer gauge until you come to the diagnostics page.
4. Press the next button until you reach the bluetooth page.
5. Press the button that says "clear". This will erase any saved phone pairing information on your Nuvi.
6. Now press the UPDT button. You should see a flashing bar at the bottom of the screen that says its upgrading the bluetooth firmware. Wait until it reaches 100% and the flashing bar goes away.
7. Once the update is complete, press exit and you should now be able to enable your bluetooth and see the bluetooth icon. You will need to re-pair your phone with your Nuvi.
The problem is, that the bluetooth update file, named "006B055301.GCD" is corrupted, so your unit is locked in the updating bluetooth mode.
Nov 04, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi710 phone book detail does not match phone contacts
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
I hope that helps.
Sep 29, 2009 | Garmin nuvi 205 GPS Receiver
Nuvi 265t: no sound or bluetooth after update
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Apr 06, 2009 | Garmin nuvi 255W GPS Receiver
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
Garmani nuvi 710 freezes on "updating bluetooth firmware 0%" when turned on
first off all remove the battery and clean the area where the battery is inserted and also press the reset button after u insert the battery and ON the device.also chage the device properly before connecting it to the bluetooth option. this many a times happens due to the humidity problem or due to the over loaded data processing.
thanks.
Jan 04, 2009 | Garmin nuvi 780 GPS
Bluetooth enabling
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Sep 01, 2007 | Garmin Nuvi 610 GPS Receiver
Garmin NUVI 710 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
