Question about Ricoh Aficio 450 Copier
How do you clean the ID sensor on Ricoh 1045?
  • 126 Answers
Take the drum unit out. right on top of drum unit there is id sensor mounted on the frame. clean it very carefully with a piece of cloth.
Posted on Oct 01, 2010
Ricoh 1045 firmware
what exactly do you need. You will need special service card also. You better call technical support
Sep 03, 2014 | Ricoh Aficio Office Equipment & Supplies
I have a ricoh aficio 2035 and there is error code sc 350, what can i do ?
SC 350 relates to problem of ID or image density sensor, first of all clean it with IP and check if problem persists go to SP mode and check in input check under modes,replace sensor if found defective,if problem resolves but recurs again check for toner flying and developer and drum life, chances of sensor failure are very less.
May 05, 2014 | Ricoh Aficio 2015 Copier
Where's laser unit ricoh 1045
when you will open the front door,right under the green handle which is for replacement of the toner bottle you will see a about 5 cm vertical line glass pull it towards you. That is the laser shield glass. Clean it whit dry cloth. that install it again and try to see the image, if the image is still the same. you will need to clean the laser unit.
Dec 06, 2013 | Ricoh Office Equipment & Supplies
Service code 385
ID sensor adjustment error during process control self-check (this check happens when you switch on). Most likely cause is a dirty ID sensor, but there are other possible reasons. Start by cleaning the ID sensor and see how it goes from there.
Nov 20, 2013 | Ricoh Aficio CL1000N Printer
Poslem poveke stranici kopiranje se pojavuva kljuch so functional problems SC350-01.Aparat Ricoh 450.
sc 350 is the ID sensor error. clean the ID sensor and it should be fine. the ID sensor is located above the drum unit.
Oct 27, 2010 | Ricoh Aficio 450 Copier
Error sc 350-1
ID sensor error
dirty id sensor-- pull out the drum unit and from the right door clean the id sensor (above the drum)with a dry cloth
Jan 07, 2010 | Ricoh Aficio 450 Copier
Error sc385 ricoh 6513
SC385: Vsg Adjustment Error
The LCD displays SC385 when the output from the ID sensor is found to be
outside 1.8 ± 0.05 V during Vsg adjustment.
Turning the power off then on resets this condition. However, SC385 is lit again after the end of each copy job even when this SC condition is reset by turning the power off then on. Toner is still supplied, but using fixed supply mode, until a subsequent Vsg adjustment is successful.
For Starters
· Dirty ID sensor
· Poor connection of connector
· Defective ID sensor
· Poor cleaning
1. Clean the ID sensor.
2. Check if the sensor connector is properly connected.
3. Replace the ID sensor.
4. Check the drum cleaning unit.
Dec 20, 2009 | Ricoh Office Equipment & Supplies
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
Ricoh 1045 sc990
Generally changing the cylinder (blade and developer) Initialize td and id sensor usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this clear the service call. If the problem persists can be the hard disk, change.
Jul 31, 2009 | Ricoh Aficio 1035 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh Aficio 450 Copier Logo
762 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
