Question about Lakewood Oil-Filled Electric Radiator Heater
I bought my lakewood heater used and when i tested it started to heat up. When i brought it home the heat was very low so i rose the thermostat. An hour later - there was no heat. whats wrong?
    Habit-Forming:
  • 155 Answers
Contact the seller, and ask him to refund you. If you can't, the problem seems to be the thermostat, or the switch.
Tries first see if the switch its on place (normally just have to pull it)
Next, if you know how to, open the heater and test the thermostat.
If don't know how, the can't help it more.
Posted on Sep 18, 2010
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
I need a thermastat
If it's for the milkhouse style heater you show in this picture then go by a new heater, they are very cheap and the thermostat would certainly cost more then it's worth. I bought a heater like the one in the picture for around $13.00 at ACO Hardware wirth low, med, high wattage settings and with thermostat of course. A thermostat would likely cost at least $10.00 plus shipping so what would you do?
Mar 03, 2010 | Lakewood 792S Utility Heater
Cord and thermostat wiring damaged by heat and/or age, both separated by short in cord where they enter the metal housing, Sunbeam heater Model 3559.
with space heaters, the first sigh of a problem is the first sign it needs to be replaced. This is your family and home you are talking about. don't risk it.
Feb 24, 2010 | Lakewood Engineering&Manufacturing PHT150...
Lakewood space heater thermostat source
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Dec 31, 2009 | Lakewood 5101 Oil Filled Radiator Heater
Lakewood oil-filled heater not heating up
It is quite possibly the thermostat. Dont risk your health these heaters are not very expensive and I would suggest going to buy a new one from your local department store.
Feb 02, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Dec 08, 2007 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
