Question about Edirol FA-101 (FA101) Audio Input
I want to connect my Edirol FA-101 using firewire to USB adaptor (my new laptop has no firewire socket) but Windows 7 - 32 bit- won't recognise hardware.
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Problem with FA-66
Judging from the wiring diagram on the cover, the headphones are connected to the same output lines as 1 & 2. When you increase or lower the monitors. So do the headsets. The only way to get around it is to find a pair of headsets with at volume control into the wiring of the headsets or plug the monitors into outputs 3 & 4.
Here is the book I saw
Posted on Sep 15, 2008
SOURCE: how do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Posted on May 18, 2009
  • 3 Answers
SOURCE: Edirol FA 66 firewire
Download/install the drivers from roland/edirol site for PC. For Mac, its plug and play. Just select the edirol in the audio options.
Posted on Dec 03, 2009
jadiazq
  • 2878 Answers
SOURCE: ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Posted on Aug 31, 2012
Ua 101 driver won't install on windows 7 64 bit
Aug 31, 2012 | Edirol UA-101 External Sound System
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
I have an acer 5740G laptop to which when i am connecting the MV 920 cannon cam corder through the camera's port in to the laptop's USB port, the laptop does not recognise this as an external removable...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. With desktop Windows PCs, you can fit an add-on Firewire interface card. This comes with a driver for the card. If your laptop doesn't have a Firewire socket, then you are probably stuck.
Nov 07, 2010 | Canon MV920 Mini DV Digital Camcorder
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
Edirol fa-66
1.i gained info about the mains supply data (9 volts 2 a, minus pole in the center pole of the plug) which is a quite exotic supply in comparison to standard devices with 12 volts an plus pole in the center pole ...
the fa 66 didn't work , when connected by 4 to 4 or 4 to 6 firewire cable .
my laptop only has a small 4 pole socket.
therefore i suppose that through this 4-pole socket and cable there was no current lead through.
after additionally connecting the fa-66 with mains supply AND 4 to 6 (fa 66 side) cable ... it finally worked.
the manufacturer should print all relevant data directly to the fa 66 device near by the socket und also print "FA-66" onto the supply ... because i own lots of alike-looking supplys and it's a drag to find out which ist good for what...
Mar 23, 2009 | Edirol FA-66 (FA66)
Oct 09, 2008 | Edirol FA-66 Sound Card
How do i get my FA-66 to work via firewire?? please help!!!!!!!
Oct 06, 2008 | Edirol FA-66 Sound Card
UA101 and Blue Screen of Death
try this to make sure that the driver was installed correctly.:
Note: Do not use the “Add New Hardware” Wizard in the control panel. Follow the steps below to install your driver correctly.
1. Plug in the USB cable and power on the device – the New Hardware Wizard will start up (wait for it to start).
2. If Windows asks to connect to Windows Update, click on “No, not this time” and click on “Next.”
3. Select “Install from a list or specified location” and click “Next.”
4. Select “Include this location in the search” and Browse to the folder containing your driver (either on your CD or the folder you downloaded). Click “Next.”
5. Click “Continue Anyway” when the Windows Logo testing screen appears.
6. Click “Finish” when the Completing the Found New Hardware Wizard screen appears.
At this point, you may need to reboot your computer. After restarting, you should check to make sure the driver was successfully installed. Go to Control Panel / Sounds and Audio Devices and make sure your device is listed under “Sound Playback” and “Sound Recording” for audio devices and “”MIDI Music Playback” for MIDI devices. You should also check in the Device Manager to make sure your MIDI or Audio device is listed under “Sound, video and game controllers” with no problems (such as the yellow exclamation point).
If everything is successful to this point, Windows has installed the device correctly and is making it available to any software you need to run. If you can not see your device in your software, you should first try re-profiling the device (different software programs do this differently). If this does not work, you may need to uninstall and reinstall the software. If you still do not see your device, you may need to contact your software vendor for more help.
- Mac OS X -
1. Make sure the Roland/Edirol device and any non-essential USB devices are disconnected.
2. Run the *.pkg installer from the CD-ROM or downloaded driver and follow the onscreen installation instructions. When finished, reboot fully.
3. Plug in the Roland/Edirol device. Ports should now be available in software (you can verify driver availability in Applications > Utilities > Audio/MIDI Setup > MIDI Devices).
- Mac OS 9.X -
Users must first decide if they want to run OMS or FreeMIDI, which can be downloaded from the World Wide Web. OMS is recommended. See the OMS or FreeMIDI documentation for installation and activation details.
Double-click the Edirol installer and follow the onscreen installation instructions.
Note: If you continue to have problems, you may wish to consider upgrading to OS X, as its Core Audio and Core MIDI features make this operating system an excellent base for music applications.
ALSO:
Product: UA-25 UA-101 FA-66 FA-101 UA-4FX UA-1EX
Pop/click/dropout is often a buffer size problem. Be sure to check your Buffer Size setting. You'll find it in the Edirol Icon in System Preferences or in the Control Panel of a Windows machine. Increase your buffer size until the problem goes away.
There are also several settings you will want to make in order for audio applications on a Windows XP computer run optimally.
One of the more detailed websites to walk through these settings is MusicXP.net.
http://www.musicxp.net/tuning_tips.php
Dec 23, 2007 | Edirol HI-SPEED USB (USB 2.0) Audio...
USB connection is not recognised by computer
Where can I download the Panasonic video camera model no. VDR-D300 from the Internet?
Nov 14, 2007 | Panasonic VDR-D300 DVD Camcorder
Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Aug 19, 2006 | Edirol UA-101 External Sound System
Edirol FA-101 (FA101) Audio Input Logo
316 people viewed this question
Top Edirol Televison & Video Experts
Electro Med Services...
Are you an Edirol Televison and Video Expert? Answer questions, earn points and help others
