Primus washing machine error 11? Is this a inlet water issue?
Error 11 is definitely a water issue. Usually it's because there is not enough pressure. Error 5 is an overload or mis-balance in the drum
Posted on Jan 07, 2011
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Error 5 means that there is a water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
Error E10
Hi
Error code e10 means Problems with water inlet or during drain cycle. To resolve the error take the cold water off the inlet tube to the washing machine. Now turn back the water back on. Also, check for filter screen at inlet valve, remove it and clean. If this doesn't work then the door is not latched properly. If this doesn't resolve the issue then you would need to replace the water valve on your machine. Hope this helps...
Please post back for any further assistance.
Daniel
Aug 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Error message F-10
Hi
Error Code F10 means Pressure switch not sensing correctly. Plesae check for the inlet water pressure. If water pressure is OK then there is an issue with the water inlet valve or pressure switch. Make sure the pipes aren't kinked or clogged. Please post back for any further assistance.
Daniel
Aug 01, 2010 | Washing Machines
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
Keep on getting the IE erorr
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Make sure water supply tap is open and not frozen. Check and clean water inlet valve from debris. If the issue persists, replace water inlet valve.
Oct 18, 2009 | LG WM1814CW Front Load Washer
Error code LE
If you are getting a "water inlet" error "IE" I found out thru trial and error that my inlet valve(s) were messed up. On my particular machine you can put the machine in trouble-shooting mode by pressing the "Spin Speed" and the "Soil Levels" at the same time and press the "Power" button while doing that. Then advance thru all the functions by pressing the "Start button"
1 time; Tumbles clockwise,
2 times Low level spin,
3 times; High speed spin,
4 times Inlet valve for prewash,
5 times; Inlet valve for main wash,
6 times, Inlet valve for Hot water,
7 times: Inlet valve for softner,
8 times; inlet valve for bleach,
9 times; tumble counter-clockwise,
10 times; turns Heater on (if equipped)
11 times; circulation pump,
12 times; drain pump,
13 times; power off and unlocks the door
Good Luck!!!
May 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
595 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
