Question about Amana Microwave Ovens
Mod mvh220e/o1mic will count down but mag will not kick in
  • Amana Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 15, 2010
MICROWAVE OVEN
You need to know if it is sending power to the Big High Voltage tranjsformer. You say it is timing down, but does it run like normal and just no heat?? Or is it timing down but not running. If that is the case probably bad door switches and bad connections to the switch. If it is running but no heat , possiblw bad magnetron or bad connections at the mag.
Oct 18, 2017 | RCA RMW741 Microwave
Microwave will count down the time but will not heat up
Only one thing heats in micro wave. If every thing works but heat, sounds like you have a bad mag tube. (Magnitron)
Sep 02, 2009 | Kenmore 62622 Microwave Oven
How to get to stirrer on amana mvh220e microwave oven?
You don't have to do that kind of disassembly to get to the stirrer on this model.
The stirrer is located under the floor plate, which is probably ceramic and certainly fragile.
It's held in place with a rubber gasket, which you should be careful not to tear.
You can use a butter knife or putty knife to gently lift up the front of the floor plate, then it will slide forward & out.
Then you'll see the stirrer.
If the gasket is torn, it should be replaced or sealed with caulk after a thorough degreasing and cleaning.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 01, 2009 | Amana MVH220W Microwave Oven
How to remove an old amana microwave from the wall model MVH-9T
remove grease traps on underside. Look inside and remove
clip(s) to wall
Open cabinet above, remove two bolts holding microwave
Slide out.
Apr 27, 2009 | Amana MVH220E Microwave Oven
Sunbeam microwave mod.#smw975
Try to unplug and plug it in back. If not helps then
possibly primary switch inside the m/w broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Microwave Ovens
GE Profile Spacemaker keeps asking for time date reset and will not operate
The power to the unit is drooping (when the heavy microwave load kicks in) causing the reset.
Try plugging it into a different outlet (whole different circuit if possible) and if that works then you have a wiring problem to the original outlet.
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
