Question about Apple iPod nano
Ipod wont show up on itunes
Ok..so i plugged my nano onto the USB and this HI-SPEED USB Device Plugged into non HI-SPEED USB Hub message showed up and so i clicked out of that and i look unto itunes to see if it was updating but it wasnt and i notced the ipod icon wasnt there so i cant download any songs into my nano then i unpluged the nano and it was stuck on th Do not disconnect screen so i reset it and now everytime i turn it off i can only turn it on by reseting it..is it my computer thats the problem or just the nano??how do i fix it?? omy iod is usedand this person has a ton of songs on here and i want to delete them but dont know how to do that and my ipod is not showing up on itunes but the computer says that it is When I connect my ipod to my pc it does not show up on my iTunes. The connection noise is still there and the ipod has the message "do not disconnect" flashing so it has connected. But it is nowhere to be found in iTunes.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Posted on Nov 30, 2008
You can try connecting it to another computer and see if it works there. If it does then it is Windows or your computer or the USB port or driver. You could also uninstall iTunes and reinstall it and then check if it connects. If it shows up then, you can select to restore it on the info screen, it will reset it back to factory and wipe it clean.
Hope this helps
Nov 27, 2008 | Apple iPod nano 2nd Generation MP3 Player
When you have a high speed device like the ipod plugged into a non high speed usb hub, all that means is that it will take the ipod about twenty times longer to load up under itunes then it will using a high speed port. Try connecting the ipod to a different usb port and see if that one is a high speed port (if it is, it will most likely have 2.0 written beside it, and if it does not have it, when you plug it in, it will tell you if it is a non high speed usb port. The same message should pop up. Try all of the usb ports on your computer. You should have at least 1 high speed port.
Nov 08, 2008 | Apple iPod classic MP3 Player
Let the iPod fully charge - sometimes you will get this message if the iPod is running on low power. Try another USB port if it gives you the same message.
If it still doesn't work, try the 5 R's suggested by Apple in the manual - you can get a manual from Apple's website if you have lost yours.
Jul 06, 2008 | Apple iPod shuffle MP3 Player
ok u go to www.myfuckingipodwontwork.com and they got answers for problems like urs
Apr 06, 2008 | Apple iPod nano
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
If that doesnt help contact the appel support.
Mar 09, 2008 | Apple iPod nano
go to applications then utilities then open disk utility
on the on the left side all the hard drives will be listed. click on your ipod then click erase, look here click "erase" and then "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
PC:
go to start, my computer. in the new window your ipod's name will apear right click then click format. make sure that quic format is checked and then click "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
Feb 19, 2008 | Apple iPod nano
Your ipod has to be plugging into a high speed usb port, that's your problem. Don't use the usb ports on front of your computer, use the one's in the back. Those are typically high speed. If you have an older computer, you might not have high speed usb ports and you'll need to purchase an pci usb 2.0 adapter.
Once you get it connected to the computer and you sync with your library it will remove any songs that were previously on the ipod.
Dec 26, 2007 | Apple iPod nano
try these websites. it can be a frustrating problem.
http://www.apple.com/support/ipod/five_rs/classic/
http://docs.info.apple.com/article.html?artnum=93716
make sure you follow all of the steps
good luck
Dec 14, 2007 | Apple iPod nano
Apple iPod nano Logo
142 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
