Question about Samsung SC-D353 Mini DV Digital Camcorder
What kind of memory card can i use with this that has more than 128 mb
    Guru:
  • 377 Answers
Download the manual for the Samsung SCD353 here:
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SCD353&mType=UM&vType=L&disp_nm=SCD353
In the English/German version, see page 87. The flash memory used with this camcorder is the Sony Memory Stick. A Secure Digital (SD) memory card will not fit and will not work with this camcorder.
Posted on Sep 15, 2010
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
Does the Bell & Howell DV65 take an external memory card, if so what kind?
Storage Memory Type: Built-in · CompactFlash Card Type I · SmartMedia Card Built-in Memory Size: 16 MB File Size (High Res.): 0.8 MB (160 images on 128MB card) File Size (Low Res.): 0.16 MB (about 800 images on 128MB card)
128 MB memory card
Jul 23, 2010 | Bell & Howell DV65 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Memory size is 64mb instead of 128mb
it's beacuse bios,it's probably set to 64 MB,go to bios ,and set it to 128 MB,and instal latest drivers,and see will that fix it....
Apr 10, 2010 | Nvidia GeForce FX 5500, (128 MB) Graphic...
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
No color on my tv
this system requires about 64 MB of system memory and requires CD ROM as a software where we can install it.
128 MB of ddr memory
display support.
  • BIOS compatible with VESA for super VGA
  • DDC1/2b/2b+ monitor support
  • VESA Display Power Management Support
Nov 28, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Samsung SC-D353 Mini DV Digital Camcorder Logo
159 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
