Question about Sanyo PLC-SP20N Multimedia Projector
Yellow band on the edge of screen
Hello Guys
I have a SANYO PLC-SP20N. it has been a good projector for the past 4 years but now it's projecting a yellow band (2 inches wide) on the edge of the screen. I was told it's the bulb and it wasn't. any advice ????
your help will be greatly appreciated.
Chucri Jalkh
  • 563 Answers
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
Posted on May 19, 2008
Picture is blue
if the projector requires a composite video cable (PbPrY) (3 rca plugins) and you only used a yellow rca video plugin it won't show the video properly
Oct 15, 2013 | Sanyo Multi-media Prox Projector, Model:...
Sanyo plc-xp30. Lamp turns on but has a yellow tint , in a circle that does not quite take up th ewhole screen. the color looks normal around the edges.
U need to unplug unit and turn on its back replace filter . blow out. sounds like its getting hot and dusty. u need to clean before u burn out your optical engine like i did.
May 25, 2011 | Sanyo PLC XP30 Multimedia Projector
Picture is wavy and jittery on some slides.
This could be a syncing issue with your computer and the projector. Try to set your display settings on your computer to a different resolution. i.e. 800x600 or 1024x768.
May 18, 2010 | Sanyo PLC-SP20N Multimedia Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
My Sanyo PLC-SP20N needs an alignment or registration - how do I adjust?
go into the menu, settings and reset the settings to factory default. then go into settings and adjust accordingly.
Nov 01, 2009 | Sanyo PLC-SP20N Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
Can not make picture bigger on my Sanyo PLC-SW20 projector
depending on the size of the surface you are projecting on, and what the zoom capacity of your lens is, you probably only have one choice available to you, and that is to move your projector farther away from what you are trying to project onto.....
hope this helps!
Jan 10, 2009 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-SP20N Multimedia Projector Logo
372 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
