Question about Northstar Garden
I have a northstar pressure washer mdl.157182D,S/N:157182. Pressure washer works but does not have much pressure coming out of the nozzle even when the adjustment knob is turned all the way in.
4 Suggested Answers
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
Monster80
  • 460 Answers
SOURCE: pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Posted on Apr 05, 2009
  • 17 Answers
SOURCE: looking for a manual for northstar pressure washer
Please use this link for more information for the manual:
http://www.northerntool.com/catalog/buyersguides/pressurewashers/
Posted on May 14, 2009
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
Have a northstar model 157182d with an electric motor and the suction tube that pickups soap or chemicals does not work. Not sure also what position it needs to be in when I want to use it.
Hi there PBM,
The siphon will only work at low pressure.
The wand should have several different nozzles. There is a specific low pressure nozzle.
If they are color coded, it is usually black, If nothing else, look for the one with the biggest opening. and attach it.
The siphon will work with it
Best regards
Mike
Apr 18, 2010 | Northstar Pressure Washer 3000 PSI
I cant figure out how to repair my turbo nozzle how do you take apart the nozzle.
Most commonly, debris gets plugged internally in the nozzle holes. Using a small pick from the outside, with the nozzle removed from the wand (it is threaded on), you can try to dislodge debris caught in the nozzle holes.
Dec 03, 2009 | Northstar Pressure Washer Turbo Nozzle
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Sep 03, 2009 | Northstar Pressure Washer 3000 PSI
Water leak
bypass valve is shot or stuck in the "open" position
Jun 15, 2009 | Northstar Pressure Washer Turbo Nozzle
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Garden Logo
158 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
