Question about Konica Minolta Office Equipment & Supplies
I have a magicolor 1690 MF and my YMC (Yellow) toner is out , can I still print black I still need to finish a project and I don't have a Y toner to replace.
Dano13
  • 11 Answers
SOURCE: Help replaceing a toner
Here is what you do.... turn off the power, open the door to access the toner cartridges. You'll see the access port to pull the cartridge out. There will be a small picture to the top left showing to use your two fingers to pull it out. Between the pic and the opening there is a square hole with a round plastic tube in the center of it. Take a car or house key and stick it in the hole. When you do, you can now rotate the cartridges by sticking your finger in the individual cartridge holes. Rotate the cartridges until to can freely pull out the one that needs to be replaced. Put the new one in, close the door, turn on the printer... Ta-DA!!
Posted on Nov 30, 2007
mosesclive
  • 191 Answers
SOURCE: diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Posted on Dec 20, 2007
SOURCE: Magicolor 2480 MF
My printer won't print after i had a paper jam
Posted on Jan 21, 2008
  • 214 Answers
SOURCE: Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Posted on Jul 01, 2008
SOURCE: Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Posted on Oct 06, 2008
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
Why does my photos art C6230 all-in-one keep saying I need to replace the black ink when the back shows 100%? The printer says it is using colors to make black print
If the machine is just using magenta, yellow and cyan to make black then you get brown, not black, (that why you have a black image unit, because YMC will not make black, color system issue. unless the machine is using yellow,magenta, cyan, then black. Are you using 3rd party toner or OEM cartridges? Did you replace the cartridge before it was required?
May 23, 2015 | Office Equipment & Supplies
UNIT DISPLAYS 1 UNIT END RELACE YMC
replace the image units Yellow, Magenta, and Cyan Image units NOT TONER
Jan 14, 2014 | Konica Minolta Magicolor 1600W Printer
0310 mf 1690
PRINT HEAD which houses the LASER replace it, or the control board
Jan 07, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Can i reset the drum unit for 1690 mf
Yes You can. I will make a video or a tutorial soon.
May 15, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta 1690 MF printer says TOner Cartrdige YM is out. I haven;t had the printer that long and have printed less than 1,000 pages.
Hi there, A lot of the new Printer/Multifunctional/Fax Machines nowadays come out with only demo Toner/Cartridges which are not completely full so there average yield is very low. The average yield for your Toner Cartridges should be around 2500 Pages but this is a measurement when you basically print in draft and with toner saving on. The moment you start using colours more intensely the yield will drop drastically.
Regards,
Jul 27, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Printing black/white when color toners are low
Try taking the color toner containers out of the printer and shaking them a bit. Put them back on and try again. This could confuse the sensors into believing that you still have some toner left.
Good luck
Dec 13, 2008 | Konica Minolta magicolor 2300DL Laser...
669 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
