Question about HP OfficeJet 6110 All-In-One InkJet Printer
Will not print from computer on request, fax and copier function correctly
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
follow this steps
1.disconect usb cable
2.uninstall your printer from your pc
3.run setup from printers cd or from the driver you can
download from Hp official site
4.follow the setup steps
5.only connecte your printer to pc when setup ask you to do
If i helped you
pls vote me
Posted on Nov 01, 2010
  • sugarmac3548 Jan 06, 2011
    It may depend on your operating system (i.e., Windows XP or Windows 7). In Windows XP you may have to go the HP's website and download your drivers, however on Windows 7 the drivers are already included. You must go to Devices and Printers on your control panel and choose this printer as your default printer. Make sure that it is checked. You will see a picture of the printer and the identification of it, i.e., HP Officejet 6110 all-in-one. Once you choose it as your default printer a green check mark will be on it. Good luck.
    Problem Solver:
  • 6 Answers
Posted on Jan 06, 2011
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
When making copies or receiving a fax there is a horizontal band that has no printing on it. The fuser oil low prompt came on but we hae since filled the oil.
Perform device functionality observations. For example ascertain that the device has least encountered any malfunctions to require repairs. Second, observe the depleteable resources either ink, print paper as mentionable examples. Print papers impressionfulness contributes towards attaining intergal text prints. Also,ink once almost depleted least produses desirably. Usually printer devices derive functionality requests from computers. Once the printer has been manipulated either as changes to depletables, the computer has to attain the new effects. Power off the entire networked devices momentarily. Repower on to make computer search to modify that printer peripheral devcies are up to date. Display logos that once malfunctioned are effective by which time.
Feb 14, 2011 | Office Equipment & Supplies
I am getting an 5C10 service error message and the computer temporarily will not print. After turning off a number of times it does print again but this is happening more frequently. How do I fix the...
Go to the Control Panel. Double click on Printers and Faxes. Right click on the mp530, click Properties, Maintenance, Cleaning. Do a test pattern when requested. If it doesn't look correct, click Cleaning again, or Deep Cleaning.
Nov 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Will not print material from the internet.
Open up the Printer Properties icon on your computer. Its location varies with OS versions, but typically click on Start, then Control Panel then Printers. Make sure your printer driver is correctly installed. Select the FAX choice and see what is set up to function as Fax; the only reason that programs call up the Fax would be if the Fax is defined as your default printer. Suggest an actual printer and set the printer as Default; printer problems should be solved. Problems? contact Jaye Ellen at jaye.ellen@gmail.com
Apr 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
When i am going for scan my machine display this massge this function requires optional equipment
Image Runner 3300 or (iR3300) copiers do not come with print/scan OPTIONS installed. These functions must be enabled by installing the correct 'kit'....same with fax option...again, these were 'options' when this machine was introduced, no print, scan, fax,...unless options were added to it. Yes, the buttons are there, however.....
Nov 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Fax
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 04, 2008 | HP PSC 2210 All-In-One InkJet Printer
Kyocera mita km2030
The Memory TX is for fax transmission only, not for your print queue. Push the printer button and highlight the go button and select it. This will take your printer online (or if already online it will take it offline). If the copier was offline, it should start printing when you select go. All of this assuming that the IP address is correct and the print driver is installed on your PC.
Please don't forget to rate your answers.
Jan 15, 2008 | Office Equipment & Supplies
Printing on Imagerunner 210s
depends on which additional function you are trying to do.
You have it as a copier only right now, you can add
duplexer for two sided copies
network for your computer to fax and print and scan
document feeder to put copies on top and feed automatically
There are a lot of options you need to decide which function you are willing to pay for.
Good luck
Dec 04, 2007 | Canon imageRUNNER 210S Copier
HP OfficeJet 6110 All-In-One InkJet Printer Logo
260 people viewed this question
Seeker5211
Seeker5211
