Dell optiplex 760 is making 3 low beeping noises for no apparent reason. They are quick and the middle tone is higher than the other two. I can't seem to figure out what it means or how to fix it. No error codes.
ginko
  • 19396 Answers
SOURCE: WHAT DOES THIS NOISE MEAN?
When disk does a noise like click click, that meant the hard drive heads are broken. Harddrive hardware is broken, data cannot be recover easily when it is like that , if the HDD contained very imprtant data you can send it an HDD data recovery.
Here is an HDD data recovery company in uk
This is the picture of a broken head:
regards
Posted on Mar 17, 2008
  • 489 Answers
SOURCE: Dell GX150 beeps 5 times on startup.
This normally means there is a memory error. Have you recently added memory to the sytem? You can try to remove and reseat all memory modules in the system to see if that clears the problem.
Posted on Jul 10, 2009
gherna1
  • 190 Answers
SOURCE: dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Posted on Aug 24, 2009
parrotheadpc
  • 2600 Answers
SOURCE: how do i replace dell optiplex 760 cd-rw/dvd
Here is the link to the service manual for your computer, since we do not know what formfactor the case is, go to the link, pick your case form and look through the manual for case opening instructions. Be sure to save a copy of the manual for yourself for a refernce.
http://support.dell.com/support/edocs/systems/op760/en/sm/index.htm
Posted on Oct 14, 2009
SOURCE: Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Posted on Jan 12, 2010
Optiplex won't start up, but when I push start button it's showing green flashing lights 1-3
There are specific patterns on a Dell that will tell you what the problem is.
http://www.tomshardware.co.uk/forum/275108-30-dell-optiplex-diagnostic-lights
Feb 10, 2015 | Dell OptiPlex 760 PC Desktop
My automatic IDE configuration has been running for a day . I have a dell optiplex 760 an would like to know ,how long should the configuration run and how to stop it ??
Perform these steps, enter system setup and reset the computer to its original Dell settings:
  1. Restart your computer.
  2. As the system restarts, press <F2> to enter system setup.
  3. When the system setup screen appears, press <Alt><F> to load the Dell default settings.
The computer beeps when the settings are restored.
  1. Verify that the time, date, and year are correct
  2. Press <Esc> and then press <Enter> to save your changes and exit.
The computer restarts.
Sep 19, 2014 | Dell OptiPlex 760 MT Desktop Computer
Continous beep sound from the mother board
make sure your cpu fan is runing and the psu fan is running if they are then it maybe your computer ram
Feb 28, 2013 | Dell OptiPlex 760 MT Desktop Computer
My Dell Optiplex GX620 is making a soft beeping noise like an alarm. Why?
It in fact may be an alarm, over heating?
If it beeps in groups, like TVs do in an error mode, look up what it means on dell's web site.
Mar 10, 2011 | Dell OptiPlex GX520 PC Desktop
When I try to install a usb camera on a Dell optiplex 760 I get 3 beeps and it won't recognise the camera
You need the installation driver software that should comes with it. If you dont have it download from the internet according the brand of your camera.
Apr 06, 2010 | Dell OptiPlex 760 MT Desktop Computer
How to turn off beeps on anOptiplex 760? Thanks.
I've got a few options that will work for you here. They are outlined below.
1.When starting up the computer, start hitting F2 to enter the BIOS.
Look under "Integrated Devices" and you will see system speaker there, and can be turned off. 2.Open up the case to your Optiplex (Simply push down release tab and remove side cover). Locate the system speaker, and unplug it. 3.Go into device manager. Right Click "My Computer" and select Manage. Choose "Device Manager" from the left side. a. Click View >Show hidden Devices.
b. Expand "Non Plug and Play Devices"
c. Double click "Beep"
d. On the Driver Tab set the "startup" type to "Disabled"
e. Reboot. Let me know if this fixes your issue. Look forward to hearing from you soon.
Feb 25, 2010 | Dell OptiPlex 760 MT Desktop Computer
What model 2 or 3 Port FireWire PCI card (low profile) Adapter?
I could not find any product that would fit a SFF case. The best suggestion i have for you is to get the riser card adapter that will fit standard PCI cards in the Dell Optiplex 7xx models. here is the link and partial discription.
The Dual Full Height Riser from Dell™ enables you to fit two PCI card in its slots. This product has been tested and validated on Dell systems and is supported by Dell Technical Support when used with a Dell.
http://accessories.us.dell.com/sna/products/Controllers/productdetail.aspx?c=us&l=en&s=dfh&cs=22&sku=430-2598&~lt=popup&~ck=TopSellers
I hope this helps you. Best Regards, -md
Nov 10, 2009 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
