Question about Mongoose 20-Inch Gravity Games BMX Freestyle Bike
The brakes are rubbing against the tire. How do you adjust them?
    Genius:
  • 1,788 Answers
Your wheel is probably bent and has to be trued. You cannot adjust your brakes without the wheel being straight. You will have to take it to get serviced unless you have a truing stand and a good quality spoke wrench.
Posted on Sep 15, 2010
2 Suggested Answers
  • 66 Answers
SOURCE: Brakes rubbing against tire and I have no idea how
A simple fix is to give the brakes a really good squeeze and this will stretch the cable just a little and should stop them from rubbing. If how ever the rubbing is happening on just one part of the wheel then your wheel may be warped and need repairing by a cycle shop.
Posted on Jun 08, 2010
How to adjust rear brakes on a 2000dodge dakota sport
These brakes have self adjusters that work in reverse. Backing up @ 3-5 mph and stepping on brake pedal constantly on-off in 30 foot sections can bring them in adjustment this may take 10 to get them close. Or you can jack up rear of truck support with stands look at the backing plate there 2 elongated holes on the bottom with truck in neutral spin tires by hand and listen for the brake shoes to rub against the drum. place a screwdriver in one of the holes that has the star wheel in it as you turn it the wheel clicks against the auto adjuster THIS IS A ONE WAY ADJUSTER so only go 3-5 clicks at a time while spinning the wheel until you get a rubbing sound that in complete full circle. do not over tighten if you do then it is harder to back off this is where the second hole come in to play get a coat hanger and cut a 8 inch piece make a small 90 degree hook similar to a allen wrench then place in under the star wheel and push inward and hold then back off adjuster. you need to be a octopus holding flashlight hook and screwdriver. Just go slow getting it close then backing up several times should good enough.
May 04, 2014 | Dodge Dakota Cars & Trucks
Burning plastic smell from drivers side rear wheel
pull off wheel and check brake pads low,caliper sticking ,or debris -if brakes look good than check hub-wheel bearing----- may be going bad
Apr 11, 2014 | 2005 Honda Accord
Rubbing sound
Hi Anonymous, if you have a wide tire check for rubbing underneath the rear fender and belt, also check front tire rubbing against fender braces. Good luck
Apr 10, 2014 | Harley Davidson XLH Sportster 883 Deluxe...
My 99 dodge durango makes a "rubbing" sound when
it might be because of the tires rubbing against the fender, as you speed up the tires expand so the can rub against the sides of the fender.
or it might be a simple brake problem, u can try getting your brakes serviced
Oct 21, 2011 | 1999 Dodge Durango
Front brake pads are not resting on the rim
Getting hand-brakes adjusted correctly is often a challenge, but they are adjustable with the right size wrenches. On the other hand, a front hand-brake on a child's one-speed bike is not necessary and is only on the bike to give it sales-appeal. If this is a one-speed bike, then it has a coaster brake (operated by pushing the pedals backwards). Actually the coaster brake is much safer than a front hand brake anyway. If the child applies the coaster brake too heavily, they will just skid. If they apply the front brake too heavily, they will go over the handlebars. If the hand brake is not interfering with the front wheel and is just not very effective, I would just leave it as-is. If the brakes rub on the tire, you should adjust them so they don't rub the tire.
Jul 23, 2010 | Dynacraft 16" Boy's Wheels Bike
Front end makes occasional noise when driving down the road. the problem seems to occur most when pressure is placed on the suspension by a bump or bump while braking. It sounds alot like something rubbing...
It sounds like pads against the rotors. Does it get louder or stop when applying the brakes?May be a stone or maybe just rust or maybe you need brakes looked at.
Jun 14, 2010 | 2006 Chrysler Town & Country
Brakes rubbing against tire and I have no idea how to fix. Schwinn Raleigh M-20. I know nothing about repairing bikes.
Jun 03, 2010 | Schwinn Cycling
Having a noticable womp womp coming from the rear
This is not an 'ASUS Z71' question.
Got a flat tire?
Or, a tire with a flat spot?
Or, got something (nails, rocks) wedged into the tire-treads?
Got worn brake-pads that are rubbing?
Got a bad expansion-cylinder inside the brake, causing the pads to rub against an out-of-round brake-drum?
(If you drive a few miles, and then touch each wheel, is one wheel is noticeably warmer than the rest?)
Mar 02, 2010 | ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000)...
2003 windstar rear brake problem.
Take the lug bolts and try putting the broad side against the drum without the tire rim. It sounds like the rear brakes are adjusted too tight. Also check the emergency brakes which may have to be adjusted looser now that the linings are new and thicker.
If you can run the lugnuts against the drum with the broadside hitting the drum you will duplicate what is happening with the tire rim. You will be able to see better and can adjust the brakes without the tire in the way.
Sep 23, 2009 | Ford Cars & Trucks
I have a 2004 Chevy 4x4, regular cab, Z71
Check the dust shield on the brake rotor's. There known to warp due to the heat of the brakes and will rub against the brake rotors or rim it self. Good luck and hope this helps, the other thing to that would create the squeak is low brake pads indicators rubbing against the rotors and it's time for new brake pads.
Sep 16, 2009 | 2004 Chevrolet Silverado
Mongoose 20-Inch Gravity Games BMX Freestyle Bike  Logo
196 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
