I just installed a new hard drive on my desktop pc. This is a second hard drive because my current one is getting full. I followed directions jumpering the new drive as the slave but my computer is not recognizing the new drive. Do I have to pull out my old drive and jumper it master? Is this all I need to do?
  • 3,940 Answers
Most computers use the cable select setting to jumper the drive. Try that setting and see if the new drive is seen in BIOS.
Once seen in BIOS, then boot to XP and initialize the drive in Disk management.
http://help.expedient.com/general/disable_firewall.shtml
Posted on May 16, 2008
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
When I turn on my averatec all in one it just has the black screen that says [F5] key for HDD Recovery. How do I get past this or can it be fixed?
Your hard drive is failing or has failed. The recover process "F5" might overwrite your data so I don't recommend it. Install a new hard drive, install the operating system and drivers. Then install your old drive as a second drive and try to copy your data from the old drive to the new drive. If you don't follow what I am saying, you need to take the computer to a professional PC service center.
Mar 08, 2015 | Computers & Internet
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Hello i ave hp compac dc7600 and i want upgrade for a best processor
Hey this PC is pretty old.
What is the current chipset in it?
I have checked the specs of the Pc and it looks like this the best processor you can put int it
Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache,
800 MHz FSB)
Not too bad but a little behind what is currently available with the i5 - i7 models.
Check what your full model number is and region then head to this page:
http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML#Configurable%20Components%20-%20Select%20Models%20%28localized%20by%20Regions%29
It will show you what can and cannot be put int the system.
Mar 29, 2011 | HP Compaq dc7600 PC Desktop
Trying to put in a sapphire radeon hd5570, wont boot all stays black!
If you've replaced your original drive with a new one, you will have to re-install the operations system (Windows) on your new drive.
If you're installing a second hard drive then
1) Set the jumper on the back of your first drive to master and the jumper on the back of you new drive to slave.
2) If the IDE connectors are all on one cable, connect one end to ide0 on you mother board, at the other end connect the end IDE connector to you current C drive and the connector in the middle to you new D drive.
With luck when you re-boot your pc should find the new drive.
Jul 03, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
May 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have an HP 513n, currently running Windows XP Pro. I'd like to install a second internal hard drive, install Windows 7 on the second drive, and then have the option of booting from the first drive under...
Yes,
It is possible its called Dual boot option.
Step 1: Create/Obtain an Installation Disc Yes, we’re all aware most motherboards these days allow you to boot from a USB flash drive, but setting that up is a guide in itself. We’re going to assume that you either already have a Windows 7 DVD, or have an ISO file. If the former is true, feel free to skip ahead to Step 2.
To create a Windows 7 disc, pop a blank DVD into your burner, and burn it as an image file with any of the countless apps that can handle ISOs. Our personal favorite is ImgBurn, but to name some others: Burn4Free CD and DVD, CDBurnerXP and Ashampoo Burning Studio Free.
Step 2: Create a New Partition Editor’s note: Before continuing I’d like to take a moment to acknowledge the fact that data corruption is a possibility. Even though this guide is absolutely harmless, random software anomalies can and do occur – do yourself a favor and backup your precious data before proceeding. Moving on to more pressing matters, we will need to create unallocated disk space by resizing an existing partition in your current hard drive, and then create a new partition on that free space for Windows 7 to run on. Most of you who are reading this will probably only have one existing partition, dedicated to the operating system you’re currently using.
With that in mind, to help you in the process of creating a new partition we’ll be looking at two separate approaches. While Windows Vista has built-in utilities to resize active partitions, XP does not, and thus we must resort to using a third party application (GParted).
Create a New Partition on Windows VistaIf you are currently running Windows Vista as your primary operating system, we can use its built-in tools to modify your hard drive partitions. You can also use a third-party tool called GParted, which we are recommending to Windows XP users (see below). You can skip to the XP section and follow the exact same directions if you prefer the GParted route for any reason. On Windows Vista, click Start and enter “diskmgmt.msc” into the search bar. A window titled “Disk Management” should open displaying basic information about the drives attached to your PC.
Right click the partition on “Disk 0” and select “Shrink Volume”.
diskmgmt-1p.png This should present you with drive capacity information as well as the option to enter an amount you'd like to “shrink” your partition by. The recommended minimum partition size for Windows 7 is 16GB, so enter a figure of that size or larger and then hit “Shrink”.
diskmgmt-2.png You should now see unallocated space on your hard drive in the capacity you specified, situated just after your now resized original partition.
Before creating a new partition and assigning a letter to it, be a perfectionist and reassign your optical drives to the next letter down from what they are now, so that your new empty partition can have whatever letter follows your first partition (probably “D”).
Right click the newly unallocated space and select “New Simple Volume...” which ought to open a wizard screen.
diskmgmt-5p.png On your way through the wizard you'll be asked to define the capacity for your new volume to be; let it occupy the entire size of the unallocated space you've created, assign it the letter that you've just freed, quick format the volume using the NTFS file system and default allocation unit size (volume label can be anything, just name it Windows 7).
diskmgmt-6p.png You should now see a healthy primary partition with the capacity and label previously defined replace the unallocated space. With that, you can move on to Step 3.
Jan 29, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Finding it difficult to install a second hard drive on hp dc7700
some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
Jan 16, 2009 | HP RT810UTABA - HP dc7700 small form...
Transfer memory from hard drive
Hey jockos,
If you're positive that it's only the motherboard on your first computer that's currently defective, you should have a number of options available to retrieve files from your hard drive.
Generally, the easiest way to do so is simply installing the hard drive into another computer. This should allow you to transfer files back and forth between the two installed drives freely, using a standard drag-and-drop method. Often step-by-step instructions on how to install a second hard drive can be found in your computer's owner's manual documentation, but may just as easily be found by looking for "how to install a second hard drive" using an online search engine.
Please keep in mind that once the hard drive has been installed onto another computer, it is strongly suggested that you only copy and transfer saved files such as word documents, spreadsheets, pictures and movies to the new drive. Transferring full programs and executable files manually may result in software conflicts/errors which may not be easily resolved.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 02, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
