Question about Sony STR-DE935
Protector comes on - Sony STR-DE935
  • Sony Master
  • 17,130 Answers
Check on the output of the set, It can be short. remove the power supply from the section to confirm.
The receiver must be discconnected also from the speakers to confirm if there is any short on them
Posted on Sep 15, 2010
My hdmi ports aren't working when tried blank screen comes on I can plug the cable connection in and have cable
If you don't have it plugged into a surge protector box it may have fried your connections. If you do have a surge protector, try reseting or push power button on surge protector unit.
Aug 15, 2017 | Televison & Video
My Singer 111W100 turns itself off and turns off the multiplug surge protector. What do I do?
USE A HIGH WATTAGE PROTECTOR. THE PROTECTOR YOU ARE USING IS PROBABLY FOR COMPUTERS.
Dec 10, 2014 | Singer Sewing Machines
It keeps blinking protetor
The protector circuit protects your amplifier from shorted speakers . One of your speakers , or more speakers are shorted out . To figure it out easily follow these instructions . Turn the unit off . Now unplug all of the speaker wire connections from the back of the unit . Turn the unit on . Make sure the volume is turned all the way down . The protector light should not light up . If it does , the problem is inside the unit itself and we'll have to be repaired at the shop . If the protector light is off than continue on as follows . Connect the speakers one at a time to the unit . Each time you connect a speaker , turn the volume control up and back down making sure the protector light does not come on . When you connect the bad speaker , the protection light should come on . Whichever speaker makes the lights come on when connected is the bad speaker and should be replaced .
Oct 21, 2010 | Sony STR-DA2ES 6.1 Channels Receiver
My desktop dont come on
1) Check THE receptacle in the surge protector the computer is plugged into.
I have found more than once that One bad receptacle in the surge protector is bad.
"Hmmm, surge protector power on light is lit." "Monitor has power, amp for the speakers has power, and the router has power."
All plugged in to the same surge protector.
Tried a table lamp into the receptacle the computer was plugged into, Nothing.
Replace surge protector.
2) Bypass the Soft Power On of the Power Supply, and see if the problem is the Power On switch, or the Power Supply.
If you bypass the Soft Power On of the Power Supply, and the Power Supply comes on, the problem is a bad Power On switch.
If you bypass the Soft Power On of the Power Supply, and the Power Supply does Not come on, the problem is the Power Supply.
If you wish to know how to perform this simple test, just state so in a Comment.
(Believe upper right of your page)
Jun 17, 2010 | E-Machines eMachines Desktop PC
Power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Instalation
Any good one would be fine!
Dec 12, 2008 | Sony Televison & Video
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Sony STR-DE935 Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
