It is saying the ADF is currently not available.
The copier reads, "The ADF is currently not available." How do I fix this?
This is going to be a two step process:
With the machine on go to service mode. Select System 1, Problem Unit Isolation, Find ADF, Select Unset, (This next step ensure you wait ten 10 seconds between) Power off the machine, 10 seconds later turn it on.
Once ready to copy. Conduct the same procedure again this time select ADF select SET this time. Power off a ten seconds later Power on. If the problem keeps coming back have a tech come out.
Mar 24, 2014 | Konica Minolta Bizhub C220 Color...
C8106
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END].
6. Selected System One
7. Problem Isolation
8. Select ADF
9. select unset
10. power off the machine
wait ten seconds power on the machine go thru this same procedure this time select set
11. power off again wait en seconds
12. power on again ADF should be operational if not get a tech out to look at it,
Jan 30, 2014 | Konica Minolta bizhub Office Equipment &...
Hello, Our Ricoh Aficio 2000 is saying to remove paper from the ADF but as far as i can see there is no Paper. Tried switching it on and off again but to no avail. Any suggestions?
Hello!
Swithing off and on do not solve your problem.
Make sure that you do not have any sort of paper in the ADF.
If you are sure that you do not have any paper, you probably have a faulty paper sensor.
Not the best help i know...
Jun 24, 2011 | Ricoh Aficio MP 2000 Black and White...
I have canon IR2010F copier with ADF and automatic feeder slips while taking the document in the feeder and makes tic tic tic tic noise while taking in the paper in the feeder, When we provide hand...
there are two locking handles for the adf on either side of the cover of adf i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
Jun 05, 2011 | Canon imageRUNNER 2010F Copier
What is ADF?
ADF is automatic document feeder. Display is saying that you need to place your paper sheet properly in the feeder.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP Laserjet 3390 printer right side hinge broken Need to check the availability of ADF assembly hinge kit wether readily available or else the top panel i.e the ADF assembly is available in the market
Sure, they are available. Take note there are two part numbers for your printer. You should see this on the back of the printer but it should not make a difference in your particular part need.
The exploded diagram for the ADF is here. You can click on an illustrated part to see its price. This seems very affordable to me on my inspection.
This is the page to start from when selecting a part. What I found is that the Keyword and Category search did not produce results. I clicked on the Select A Diagram link and the selected the product for the ADF in the Category drop down list. This results in a parts explosion where each part shown is a clickable link to a part listing including price.
You should be able to select and purchase from there.
The ADF Top Cover was only $14. That seems pretty fair but I suggest you look at the part explosions and you will know more of which part you need and want exactly.
Thanks for using FixYa,
Worldvet
Dec 10, 2008 | HP LaserJet 3390 Printer
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
ADF jam
Turn off printer and unplug it from power supply.
Check ADF if it appears to be damaged ( open the top portion so that you can check the mechanisms ) unplug the ADF cable from back of scanner and replug it, replug power cable, turn it on and try scanning using adf again.
Feb 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
801 people viewed this question
k24674
jasbo
jasbo
