Are you able to view the same Red lines even in the BIOS window? If yes, this may be LCD issue too.. The LCD will show small red dots which are called Dead Pixels. If the Red lines and dots are more, then it is better to contact the Service Center
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
If you are att customer, you will be charged $60 only if there is problem inside your premises, otherwise they wont charge you.
Is there any phone connected with your DSL line? if so is it working? if its not working, contact customer support and tell them its not working
If the phone is working, you have to check the connections between the phone line to the modem. As the DSL light is blinking red, its the problem with line and not the modem.
It may be loose contact inside the monitor Or May be the LOT (Line output Transformer) and V-Transformer If the monitor is under warranty, contact the vendor for getting the replacement if the monitor is not under warranty get contact the good mechanic for repairing the monitor
Let me know if your problem is solved and rate me as FIXYA!
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels.
Direct from their site:
"The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call."
http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
