Question about Lexmark T644 Laser Printer
Paper has peppered streak down right side of paper. Ink rubs off on hands.
Corysf62
  • 188 Answers
SOURCE: prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Posted on Oct 04, 2008
Ajkill
  • 2035 Answers
SOURCE: Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 11, 2009
amfigue
SOURCE: Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Posted on Mar 24, 2009
SOURCE: Lexmark T 640 leaving faint black lines on right side of page
replace your cartridge, and all should be fine.
Posted on Apr 01, 2009
SOURCE: Ink is smudging on paper
Try replacing the fuser bulb located inside the fuser roller. This is accessible from the back of the printer. Remove the plastic piece on the back, unplug the two wire connections to the fuser, remove the toner wiper on top, and then remove the fuser. On one side of the fuser, you'll have a protruded plastic piece with two screws in it. Remove that piece and you'll see one more very tiny screw on top and another regular sized screw on bottom. Remove those both and the plastic piece. Inside you'll find the fuser bulb.
Posted on Apr 09, 2009
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
My HP OfficeJet J6480 All-in-One is leaving black vertical streaks on each side of the page when using the document feeder. Does not leave streaks when using the flatbed scanner. How do I correct
Hi
Just remove the ink cartridge. Clean the print head by a soft cloth with rubbing alcohol to remove some sticky or ink residue. Then rub the printhead into a plain paper until ink flows. Then run the print nozzle for 2 times.
I hope it helps you. Regards
Apr 09, 2011 | HP J4680 Office Jet All-In-One Printer
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
Why does my epson stylus 1400 leave streaks in the print?
The tracking wheels (spiked wheels) can pick up ink and lay it back down. They can also accumulate debris that collect ink and put it down in the form of streaks. This is especially true if you use dusty or moist papers (or frosting sheets).
Oct 11, 2009 | Epson Stylus 1400 InkJet Photo Printer
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Sep 17, 2009 | Lexmark Office Equipment & Supplies
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Lexmark T644 Laser Printer Logo
277 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
