Question about Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard
Power wont turn on with M957G mobo
CPU friend a while back, replaced with this mobo and new parts, and when the power button is hit, there is no power anywhere in the system. I wanted to know if anyone could link me a picture of where to connect the power switch button and etc from the case to the mobo because I tried google and could not find one. Thanks.
  • Jason May 11, 2010
    Do you have the model # of your motherboard?
Referenced maula images do not contain the necessary information.
Posted on Aug 24, 2008
Try and check the manual you will see the picture there thanks
Posted on May 26, 2008
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Can't plug in power on button cable to new motherboard
Look closely at the new MOboard silk screened lettering to find where the power button wires and the leds go. They're there, just might be in a different place.
May 09, 2017 | Acer Aspire AM1610-U1201A PC Desktop
When I hit the power button it wont turn on. I have replaced the RAM with a known working DDR400 1GB stick, no fix. Tried switching power supplies, no fix, tried new videocard since when it was last on (a...
When you say the CMOS is set to reset, this should not be the case for normal usage. and maybe the problem if left in the on position the system will not start (which sounds like your problem).
Mar 18, 2011 | DFI NF4X INFINITY Motherboard
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Was diagnos bad pwr supply,replaced power supply & now it wont do
I assume that you have a video card, and ram plugged in otherwise no startup. If so and you are absolutely certain of good power supply then it could be dead CPU / mobo. Did you buy a new power supply and ensure that the CPU power plug is plugged on the mobo?
Oct 19, 2009 | Computers & Internet
M957g mb
This is a PC-Chips model M957G and is still in production.
Google is your friend.
Apr 03, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
Wont post and buzzing noise
Don't mean to butt in here but I'll bet the 4 pin_ATX 12v connector is not connected to the board. That 4 pin_ATX 12v connector give's the CPU it's power. Without is the system will not boot. Some boards will give off that weird sound you are hearing.
Feb 29, 2008 | Computers & Internet
E-machine t2682 desktop
cpu setting in good jumper on mobo set on 1 2 pin not 2 3 for reset ? could be bad mobo what socket mobo do uuusse
Jan 21, 2008 | E-Machines T2682 (000002965) PC Desktop
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard Logo
103 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
