Question about Acer Aspire One AOA150-1457 Notebook
Check cable connection...!PXE-MOF:Exiting Intel PXE ROM.No bootable device-insert boot disk and press any key
5 Suggested Answers
SOURCE: PXE E61: media test failure, check cable PXE-MOF:
try to check if your hardisk is plugged properly, i had encountered it before. same response i got from the computer. "insert boot disk and press any key"
Posted on May 03, 2010
igor106
  • 277 Answers
SOURCE: my Toshiba at start up
If I understand you well, before Windows loads, you get a notification about the ethernet controler which is waiting for a boot data stream to come from a local server. If you don't use a client-server network setup, you'll need to go to BIOS and change the boot options, so that your hard drive is set as first boot device, then DVD as second boot device, then USB drive as fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot device, and in corporate networks PCs get such a setup so that there's one large server feeding data to the local cubicle PCs. In some cases the server-dependancy is set to such extent that these cubicle units are just "dumb terminals". In your situation, your PC thinks it should also get boot infro from the LAN, but as your PC is not a part of a corporate network it waits in vain, and after a while it should move on to the second/third boot device, and eventually find that it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option. This will fix the problem only if your hard drive is OK and you've installed Windows on it.
If your hard drive is failing/gone, then your laptop may not even recognize it and therefore moves on to the next bootable device, which is usually the DVD, and then a USB drive and lastly LAN boot.
Anyway, go to BIOS, and see what is the current setup. If the hard drive is set as first boot option, then this is a good sign that you'll need a new drive.
If this was informative please give it a Thumb Up. Thank you.
Posted on Jan 20, 2011
evan89
  • 356 Answers
SOURCE: My daughter's ACER inspire one
Sounds like your hd might be dead.
Posted on Mar 06, 2011
  • 132 Answers
SOURCE: Check cable connection..! PXE-E63: Error while
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Posted on Jun 16, 2011
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Aug 01, 2014 | Toshiba Satellite Computers & Internet
Wont go past first screen
First try this unplug from AC, remove battery, plug in try to boot normally. If that fails Open BIOS, Boot Order or the BOOT MENU, Boot from HDD first, and save changes and reboot, if that fails try a system restore/recovery.
Dec 09, 2012 | Toshiba Computers & Internet
No bootable device packard bell-what do i do?
check your bios settings and make sure your hard drive is first in the boot order.
Nov 24, 2012 | Computers & Internet
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
May 25, 2012 | Computers & Internet
Pxe-m0f : Exiting intel pxe rom
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 19, 2012 | Acer Computers & Internet
It says check cable connection! PXE-E63:Error while initializing the NIC PXE-MOF:Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key
This could mean a few different things:
1.) Your hard drive is bad.
2.) Your hard drive cable is bad.
3.) The cable that connects to your hard drive is loose.
If you are under warranty, I would advise you to contact the MFG. to have them replace the drive or check it out for you.
Mar 15, 2011 | Computers & Internet
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
Jul 02, 2017 | Acer Aspire One PC Notebook
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Acer Aspire One AOA150-1457 Notebook Logo
658 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
