Question about Samsung Digimax D73 Digital Camera
My camera is plugged into the computer via a usb cable it has no batteries in the camera should the camera still turn on or does it need batteries in
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The camera needs batteries to operate.
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Jun 17, 2011
Camera saying connection fail when trying to transfer photos to pc via usb cable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sep 14, 2014 | Pentax Optio Cameras
When I try to download photos from my S2700 to my computer, via a USB, the computer does not recognise the camera and the charging light flashes rapidly when the cable is attached and camera turns its
Apr 21, 2014 | Nikon Coolpix S2700 16 Megapixel Compact...
Trying to transfer pictures to computer. With camera turned off I plug in the kodak usb cable, then try to turn camera back on. Camera will not turn on. Battery is charged.
Jun 12, 2011 | Kodak Easyshare M381 Digital Camera
WHEN CAMERA CONECTED TO COMPUTER VIA USB CABLE CAMERA WONT TURN ON
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 02, 2011 | Kodak EASYSHARE M1063 Digital Camera
I cannot access pictures on my memory card when i connect the camera to my computer. its canon powershot sd750.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
What usb cable do i need to recharge my camera and how do i upload photos onto my computer.
The DSC-W55 doesn't charge batteries via the USB port. It comes with a separate battery charger, which plugs into a wall outlet.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
I have an M883 Digital Camera, and when I plug the USB cable into the computer and connect it to my camera to turn it on, the little green light below the "review" button blinks but the camera won't turn...
Aug 06, 2010 | Kodak EasyShare M883 Digital Camera
It will not charge
I have the exact camera, when you plug it in does the USB cable show red? If so this means the cable and the battery are connected and the red is a charging status. If you can turn on the camera while it's plugged in then its not the cord or the camera but the battery. If it just fails to charge but does power up and connect via USB i would look into a new bettery. If the USB cable does NOT respond at all when plugged into the PC by itself then the cable is bad and you need a new one. It will flash red/green/yellow if it's 100% functional. If your cable does respond but does nothing when the camera is plugged in then it may also be the cable's connections or the camera's internal port has been damaged. If you want to make sure it is the battery then plug in your cable, wait for it to cycle through the colors and connect your camera WITHOUT the battery inserted. It should do nothing, then while its connected to the cable insert the battery, If the cable turns red but will not charge then it's 95% a battery issue.
Jun 28, 2010 | Samsung SL420 Digital Camera
Not uploading to Mac with USB cable
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Samsung Digimax D73 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
