Question about Rotary Eagle White Light Dimmer Switch Push On/off
It's an old eagle single pole dimmer switch I'm trying to install. It has two hard connectors (screws) on the top and one black wire on the bottom. The switch I am replacing had just two hard wires (both black) attached. I simply put the two black leads which came to the old switch on the two connectors on the top of the dimmer and it did not work. I left the black wire coming from the dimmer capped with a wire nut. How should I wire this?
    Novelist:
  • 107 Answers
My suspicion is that instead of connecting to the two screw terminals, you should connect one of your house wires to the black wire - and the other house wire to one of those screw terminals.
Posted on Oct 18, 2010
Can I just cut the black wires coming out of old switch and connect with wire nuts to black wires of new switch? And cap off the ground wire from new switch since no ground on old switch?
You could do that but it would not be up to the electrical code requirements. Take the old one out and remove the wire nuts and put the new one in. There should be a ground wire stuffed in the box somewhere. Unless the house is really old. You connect the ground wire to the bare ones in the box.
Nov 20, 2016 | Lutron Electrical Supplies
CSB115STA cooper single pole light switch install diagram
Neutral wire is NEVER connected to a switch:
Your box may not have a neutral wire, but still the box can have a white wire.
Copy following link for switch wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html
Dec 03, 2011 | Cooper Lighting Electrical Supplies
I am replacing an existing switch/single outlet, the outlet was always live.the switch controlled a light. the existing sw was very old and only has connections on the back top.. The left had 2 white wires...
White wires under the silver screw...
The black wire under the black screw...
and the red wire under the brass screw...
If it does not work right then switch the red and black wires...
heatman101
Apr 20, 2011 | Pass & Seymour / Legrand 1595-2SWT...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
Jun 27, 2009 | AMS Lutron S2-LFSQ Skylark Dual...
Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
May 28, 2009 | Solar Levitron Decorator Style Slide...
1 way and 3 way dimmer switches
The answer to your question depends on the manufacturer and type of 3 way dimmer you are using... generally you can use a 3 way switch as a single pole switch, but whether or not this holds true with the dimmer you are using depends. Let me know what you are trying to acomplish and model numbers mfgs of what you have and I'll try and help
Jan 05, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Rotary Eagle White  Light Dimmer Switch Push On/off Logo
98 people viewed this question
Top Rotary Electrical Supplies Experts
ken skalski
Steve
bobalix
Are you a Rotary Electrical Supply Expert? Answer questions, earn points and help others
