Question about Maytag Neptune Washer
At the beginning of the spin cycle my machine stops and says the load is out of balance. Nothing I do will balance the load. Everything else works fine
  • Maytag Master
  • 17,129 Answers
Have you noticed that there is an imbalance when the spin cycle takes over? possible then that the motor is taking in more current than required to give this errror message.
Check if the washer spindle is tight , if so remove and make it free or use a good degreasing spray.
If you have bedsheets on when the fault occured roll them over to balance.
If the drum suspension is moving freely?
If the motor is faulty to bring up the RPM, check if thre is any bush bearing failure of the motor ,use a degreasing spray.
please respond.
Posted on Sep 15, 2010
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Washing Machines
Badly out of balance in spin cycle. When the machine goes to the spin cycle it vibrates and begins to walk. The machine will not balance the load small or large.
The legs underneath the machine become stuck from rust and corrosion. I had the same problem and all the repairman did was hit the legs with a screwdriver and it unfroze the legs and fixed the problem!!
Apr 19, 2010 | Maytag Ensignia MAV4757AWW Top Load Washer
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
WD 8030 W Front Loader
the load is off balace you may need to add more clothes or stop the machine and wring the water out and try to spin again( i also have an LG and mine wont spin if ther is only one item in it
Feb 13, 2008 | LG WM1812C Front Load Washer
WMA62 aborts all programs after 2 initial spins
if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
