Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Timer does not activate setting wheel. Stays on or off all the time.
1) If wheel is not turning, then replace motor
http://www.aplussupply.com/intermatic/timermotors.htm
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
There are numbers printed on clock motor. Also look inside door to see model number of timer. If you have a T101 or T103, T104 the T100 motor will work.
2) If manual override is not working, then replace whole timer.
3) You can buy same timer, and then swap insides
without replacing box. For example if you have T101R, the R stands for rain-tight box. Buy T101 and swap insides. Keep in mind T103 and T104 and T101 are not interchangeable due to wiring differences.
http:waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Posted on Sep 25, 2010
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
How to set the defrost duration on a timer
Copy following link for defrost timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
There are 2 general types defrost timers.
Time activated - Time terminated
Time activated - Temperature-pressure terminated, with timed termination back-up
Here is basic image:
http://waterheatertimer.org/images/8145-work-image.jpg
Rotate dial until current time lines up with pointer, insert tripper pin on outside edge of dial to select defrost start-time, move defrost duration tripper on inner dial to set termination time.
Each defrost timer is slightly different:
If timer is time-terminated, then wiring follows certain diagram.
If timer is temperature-pressure terminated, then different wiring diagram is used.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 11, 2012 | Paragon 8145-20 Defrost Timer
User's guide for kambrook electronic timer kd94
Could not find a free guide, but e-how lists the basic instructions.
Instructions
    • 1 Set the day and time on the timer. Press and hold "Clock." While holding the "Clock" button, press "Day" to scroll through the days of the week and select the correct one. Press the "Hours" and "Min" buttons to select the correct time. Release "Clock" when you are finished.
    • 2 Press "Prog" set the "On" time for the switch. The word "On" and the number "1" will appear on the left side of the display.
    • 3 Press "Day" to choose an individual day or a block of days. Choosing an individual day means that this specific program will only activate on that day; choosing a block of days means that the program will be active on each day in the chosen block.
    • 4 Set the time that you want the timer to switch on by using the "Hours" and "Min" buttons to select the appropriate time. Press "Prog" when you are done to complete your entry of the "On" time.
    • 5 Select the "Off" time for your timer by using the "Day," "Hours" and "Min" buttons to choose when you want the timer to switch off. Press "Prog" again to save this entry. Repeat steps two through six to set additional timers.
    • 6 Press "Day" and "Hours" to activate the random timer mode. An "R" will appear on the LCD screen, indicating that the timer is in Random mode. This will cause your timer to switch on and off at different times, following no set pattern.
    • 7 Press the button that looks like a hand with the index finger extended to perform a manual override. The display will show you whether it is in Manual or Auto mode, and whether it is turned on or off. "Manual On" means that the time is switched permanently on while "Manual Off" indicates that the timer is turned off. "Auto Off" activates the program that you have set, while "Auto On" turns the time on until the next schedule "Off" time, after which it continues to follow your programmed times.
    • 8 Press "Clock" and "Prog" at the same time to use the countdown feature. Use the "Hours" and "Min" buttons to select the length of the countdown, and press "Manual" to start.
    • 9 To reset the entire unit and clear all programmed times, use the end of a paper clip or a ball-point pen to press the "Reset" button, located above the "Manual" button.
Read more : http://www.ehow.com/how_5565934_program-kambrook-timer-switch.html How to Program Kambrook Timer Switch eHow
Nov 24, 2011 | Hardware & Accessories
I put the timer on my lamp and it stays on even if it's not the time that I set, and then it turns off when the time is up... Why does it stay on? And not go according to the timer?
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Jun 26, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
I have a HB31R timer and asm having difficulty setting the timer. Please help.
Make sure the on and off indicators are approximately an hour away from the current time you wish to set the timer to. Using your thumb and one of your fingers (ring, index or middle) grasp the edge of the yellow time indicator. Pull the time indicator straight out away from the back of the unit. While the time indicator is pulled out rotate the wheel to the correct time in reference to the time pointer. Release the time indicator and set the on and off indicators to the desired times in reference to the time printed on the time indicator. Manually move the bottom switch to on or off state which the timer should be at the current time. If you do not see the time wheel move after approximately 30 minutes the timer could be defective.
Mar 03, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My intermatic controller only works manually?
That is a 120 volt timer with a 24 volt output .. if the valves are being activated manually but the clock wheel is not turning to select the zones automatically, first check the wheel . it can become hung up when setting the time, and not be set on its spindlle so it can rotate with the clock motor. If the clock wheel is set and still does not turn, then the clock may be bad
Please vote !!
May 12, 2010 | Intermatic T8845PV - Sprinkler-Irrigation...
Timer will not advance to keep the time.
Clock motor bad? Wiring reversed?
Wiring and troubleshoot and parts list following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Aug 27, 2017 | Intermatic & Indoor/Outdoor Rain Tight...
Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Jan 03, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
175 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
