Question about Samsung Microwave Ovens
Samsung BCE1197 oven stopped working after making a noise which I think may have been the fan, maybe something caught in the fans blade or a mechanical problem, anyway I changed the fuse in the plug, still no good, having looked on the internet at other problem pages I think there maybe another fuse internally, however I do not know how to locate it, also I understand there is a capacitor, how do I discharge it safely without harming myself, is there anything else I should be looking for that has stopped the oven?
  • Samsung Master
  • 9,098 Answers
Since this is a UK Model, I'd suggest you contact Samsung's to find service info here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
Fan making a noise
I would bet that the blade is loose on the shaft.
Sometimes glue can fix that.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 15, 2013 | Hotpoint RVM1435 Microwave Oven
Smh9187w vent fan popping noise
There are no bulletins covering a recurring issue with the exhaust fan on this model, so I would suspect the failing motor, an obstruction in the blades, a loose blade assembly, or a damaged wire arcing to the frame.
It will take some visual inspection with the oven removed from the wall (see your installation instructions) and the cover removed.
The service manuals for the variants are here:
http://www.microwavedisplay.com/smh7185_smh9187w_xaa_sm.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v1.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v2.pdf
http://www.microwavedisplay.com/smh9187b_smh9187w_smh9187b_xaa_sm.pdf
You can order Samsung parts from the Pros here or from Encompass here.
Dec 11, 2012 | Samsung SMH9187 Microwave Oven
Exhaust Fan makes noise
Check to make sure that nothing is obstructing the fan blade causing the noise, if not then the bearings in the fan motor are more than likely going out causing the metal on metal noise.
Apr 24, 2012 | GE Microwave Ovens
Fan makes a terrible rattling noise
The fan blade may have come loose from the shaft or the fan motor bearings are shot. Repair is accomplished by replacing the blade or motor. If the fan is not operating correctly the magnetron will star to overheat and the oven will shut down.
Jun 21, 2010 | GE Microwave Ovens
HOW TO REPAIR MAYTAG MMV4205AAW MICROWAVE NOISY FAN
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Jan 11, 2010 | Maytag Appliances Over-the-Range Microwave...
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Noise on starting up
If the unit is cooking ok, then it sounds like possibly your cooling fan has the blower wheel rubbing and when the rpm's come up, the blower wheel migrates away from the rubbing surface. It is very common for a blower wheel to loosen up, or a bearing in the bottom end of the blower to fail, causing the sound.
If you dare to venture into the unknown, you can investigate the noise and maybe be able to adjust the attitude of the blower wheel or fan blade, which ever is loose
Post me if I can be of more help.
Thank you,
Dave E. (Illeagle)
Jun 08, 2008 | Maytag MMV5186A Microwave Oven
GE Microwave Model JES735
Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
Nov 06, 2007 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
216 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
