Question about GE Heating & Cooling
Need a replacement thru the wall ac unit for model ajch10acm1, 115 v, 15 amp 9600 btu.
    Scholar:
  • 57 Answers
Measure the cabinet dimensions. then best place to check for replacement is Home Depot ,Lowe's, sometimes Sams Club, B.J.'s or Cosco these places buy in large volume and are hard to beat when it comes to price. The 115 volt units go up to 12,000 BTU. which is one ton. If you hit at the right time of year I,ve seen a/c units around 6,000 btu sold for as low as $69.00.
Shop around most all brands are about the same. Cost is based on the number of bells and whistles you want. The most simple units cost the least also the less that can go wrong. I have found it really hard to find exact demention replacements.
Posted on May 18, 2008
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Heating & Cooling
I have a 5-6yr old Maytag 11kBTU thru-wall AC unit
It should have screws on either side of the plastic part. Take those off and it will take some work to remove it. I cannot find my manual.
May 24, 2010 | Maytag M7Y10F2A Air Conditioner
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Trru the Wall Oversized
    Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
    Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
    Heating & Cooling Logo
    81 people viewed this question
    Top GE Heating & Cooling Experts
    ray gallant
    Jay Plesset
    Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
