Question about Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
Where does the hose attach? - Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
    Scholar:
  • 143 Answers
The air hose has a fitting on it that you must pull back as you press on male part inside the female part on the actual compressor. After it is inserted it will not come out unless you do the same thing but pull instead of pressing. The other end attaches to the nailer or whatever you are using as well. Thanks BB
Posted on Sep 15, 2010
Kirby works with the brush roller head; but not the hose attachment (won't start with hose attachment)
The part of the hose that attaches to the vacuum should push on the switch on the front of the vacuum so it won't come on without the nozzle or hose attached. Inspect the hose to see if that part may be broken or not making good contact to activate the switch,
Feb 26, 2018 | Kirby Vacuums
How do I reattach the air hose to a 1.5 gal compressor?
I should hope the air hose and the knurled fitting have been attached recently.
If so, here is how to re-attach them.
Take the knurled part in your fingers, and push it away from where the hose attaches.
It should move "backwards" about a quarter to 1/2 of an inch.
This should allow the hose fitting to be installed in the coupling hole. Then, release the knurled fitting and it should lock in place.
Be advised, if the hose has never been attached to the knurled fitting, perhaps it is the wrong one.
There are more than one size and shape of fitting attachments.
God bless your efforts
Oct 12, 2015 | Air Tools & Compressors
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
How do i release. the hose to attach the attachments?
Near the carpet attachment, on the lefthand side of the hose, there should be a release mechanism that you simply push in with your foot while pulling on the hose/wand. Once the carpet attachment is removed, you can connect the other attachments. Push the release toward the hose.
Nov 04, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
How do i change the radatior hose with no clamps?
The hose your talking about cant be fixed. You need to go to the parts store like autozone and they can order you a new hose which will be the plastic part tube that broke with the rubber hoses attached to both ends. This happened to my car to. It was the plastic hose right next to the battery that had a small hose attached to it that went to the overflow tank. I think it was around 26 $ and wasn't to hard to replace. There is about 6 inches of rubber hose attached to each side and that's where the clamps are.
Mar 28, 2010 | 2001 Ford Taurus
Where do I find garden hose attachment
You can find garden hose attachments at a lot of different places. Your local hardware store ought to have a variety of attachments to choose from. Many stores like lowes and home depot carry things like this in the garden center. When to Plant Garden
Jun 07, 2009 | McCulloch FH180A Electric Pressure Washer
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor Logo
111 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
