Question about Samsung Refrigerators
Changed water filter and water dispencer now does not work,checked all pipe work,all ok up to when it goes through the clear pipe out of the pump,dont get no flow through it at all??worked ok until i changed the filter??
    Genius:
  • 1,073 Answers
Make sure that the filter is completly inserted into the housing
Posted on May 16, 2008
Ice maker and water dispencer don't work
Can be the water valves located on the back of the refrigerator. There are a lot of youtube videos to check the valve and replace them. Good luck.
Jul 03, 2016 | Kenmore Sears Refrigerator Replacement Ice...
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
ED25DWXTN01 AFTER DISCONNECTING AND MOVING TO A NEW LOCATION I CANNOT GET WATER FROM DISPENSOR OR WATER UP TO THE ICE MAKER IS THERE A WAY TO BLEED THE SYSTEM?
In effect the only thing different is you moved the fridge and switched the water off. Make sure the water is getting to the fridge pipes connected to the fridge valves.(normally blue in colour.). If not rectify problem. If water is there, suggest you remove water filter in the fridge compartment and by pressing the water dispencer button see if water runs out at the filter adaptor. If not, there is an issue with the solonoid valve/s (very unlikely thougf) Could very possibly be the water is frozen and needs defrosting. Because there are variables that i havent been given, im surmising a lot. Normally when you depress any of the dispencing buttons,a clicking sound will be heard from the solonoids at the back. Simply the water should flow up the pipe to the filter then to the dispencer outlets. Most of the time, the water is either off or filter is blocked or limit switches at dispenser end is faulty. Very unlikely that both are defective at once so check the filter and water supply. If stuck, email me on terfou@imaginet.co.za
Sep 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water dispenser has a low flow and the filter has been changed recently?
You need to try another filter before looking for a fault. If still blocking, switch water off then unscrew "filter holding bracket" 2 pipes connected. one from the water supply and the other to the to the dispencer. Open the water pressure and inspect the rate that the water flows.from the supply. If satisfactory, try and connect the one pipe to the other and retry water pressure. if not strong, problem is in second section of pipe. Rectify.
Sep 24, 2009 | GE Refrigerators
Front load washer will not fill with cold water and will just stop at the rinse cycle and buzz
Check your inlet pipe on cold water supply, When you dissconnect look inside where pipe fits onto machine you will see a small filter, if it is blocked take it out with great care and clean. always replace it. if your water supply is ok and filter is clear then it will be a faulty water valve. Good luck and feel free to give feed back ok.
John
Sep 03, 2009 | Kenmore Washing Machines
The pump on my hoover washer hnf7148 has been changed but the problem persists. Water is still in the drum and it will not drain away. The control panel when the machine stos shows the door closed with...
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Jun 24, 2009 | Hoover Washing Machines
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
