Question about Bunn CDBCF 35 Coffee Maker
Best way to prevent lime and scale build up - Bunn CDBCF 35 Coffee Maker
    President:
  • 1,618 Answers
Install an inline softener and filter, maybe a 7SO from everpure, Bunn might have some filters for sale also.
Posted on Sep 15, 2010
Horrible damp smell in my easi logic 1500 washing machine, what's the best cause of action?
Check the drainage of the machine.nothing like stagnant water sitting in the hoses and bottom of machine to cause smells.first check the penny / button trap for coins or debris as this will cause unsatisfactory emptying .do a rinse cycle with no cloths in machine.Get some calgon or anything that removes washing machine or dishwasher lime scale.then do a full wash without clothes on 60 degrees or above with small amount of bleach and lime scale remover.make sure the room is well ventilated.never overfill machine with dirty laundry when washing as this prevents the rinse cycles from removing bad water completely.try leaving the door slightly open between washes but only if you have no pets or children to prevent build up of damp spores.
Feb 19, 2015 | Washing Machines
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
Water is lime heavy in my area and I am conscious this can build up in washing machines. How can I prevent a build up. Someone suggested using vinegar to rinse the drum but didn't know how much or...
You can use about a full gallon, run the washer full to highest load level, then add the vinegar let it agitate for a minute then turn it off with the drum full and let it set (longer the better) and the when done let it finish cycle (the rinse cycles will flush the vinegar and any lime dissolved)
I use a similar process to to remove scale from shower heads, my humidifier etc
Jun 12, 2011 | Computers & Internet
Lime build up on coil has to be cleaned weekly how do i prevent so much and many times cleaning the coils is their a additive i can add or device to prevent
You could add an inline water supply filter. That would help some, since it appears you have a hard water situation. A 50/50 solution of white vinegar and water will clean the existing lime scale. Adding a whole house water softener is also a good solution.
Hope this helps solve your problem.
Mar 15, 2011 | Honeywell HM509H8908 Humidifier
Water shoots out when trying to steam.
You are getting a lime (scale) build-up in the iron. Best to try a clean, either with a self-clean function, or buying a lime remover solution for kettles and irons.
Dec 09, 2010 | Black & Decker D2030 Iron
CDBCF15 Brewer seems to have a stuck solonoid - not completely open, or closed. Can it be taken apart and cleaned - or just replaced?
lime and scale can build up in the unit and cause this problem
Best thing to do is replace the solenoid.
Also replace the in-line water filter.
If no filter, it would be best to add one to the water supply line.
Jan 02, 2010 | Bunn CDBCF15, CDBCF35 automatic coffee...
Can hard water be used i n front loading washing machine
Hi.
No prob, but it would be adviseable to use a product called CALGON, it is a water softning powder, and will prevent build up of lime scale in washer due to hard water.
Please rate my solution.
Thanks.
Oct 23, 2009 | Whirlpool Washing Machines
LIMESCALE BUILD UP
To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
May 12, 2009 | Irons
Preventive maintenance?
You should buy some c.l.r. (calcium,lime,rust) remover.It's packaged in a grey bottle at any supermarket,drug store,ect.Pour a cup in and run a cycle once a month.This will prevent any lime build up from scaling the dishwasher due to hard water.
Mar 19, 2009 | Dishwashers
Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Mar 12, 2009 | Bosch Dishwashers
Bunn CDBCF 35 Coffee Maker Logo
42 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
