Question about HP Photosmart 3210 All-In-One InkJet Printer
I'm getting an error 0xc18a0001 on my hp 3210 printer. What does it mean? How do i fix it?
  • HP Master
  • 1,684 Answers
That code indicates the the printer has the "Ink System Failure" error. This is usually reset-able. That error is normally caused by air in the ink cartridge system. To clear the error you will need to do a purge. We have a free complete guide to perform the purge at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Sep 15, 2010
3 Suggested Answers
cene765
  • 787 Answers
SOURCE: My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Oct 07, 2009
caroldon
  • 17129 Answers
SOURCE: I have a 3210 HP
It is quite possible that the printer software has some errors and so there is communication errors betweent he PC and the printer . Sometimes a reset can help and so remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and then connect the Printer to be detected and installed as a new hardwarre. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Posted on Apr 05, 2011
HP 3210: Fehler Oxc 18a0001
The only way to fix Oxc18a errors is to reset the printer. You can find the instructions on www.inkbank.com.au website here:
HP ink system failure error HP maintenance error what to do if HP printer...
Jan 01, 2015 | HP Photosmart 3210 Printer
HP Photosmart 3210 -Ink System failure - Error 0xc18a0001
In addition to having the ink system failure error 0xc18a0001, my printer screen also read improper shutdown. After trying most of the above solutions with no success, I did a search for the improper shutdown problem. This is where I found my solution!
The solution is under "Printer will not start" the solution post is by speters9971. "...you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord."
This is what solved my problem after hours of searching & repetitive similar solutions!!! The above solutions did not help; some of them seemed to be incomplete or irrelevant for my model. I have a HP Photosmart 3210 All-in-One.
Thank you speters9971!!!!!!!
May 27, 2008 | HP Photosmart 3210 All-In-One InkJet...
MY HP PHOTOSMART D7100 IS HAVING A PROBLEM ERR 0XC18A0001 IS IT FIXABLE?
The error means
PrintHead Failure / Ink system Failure
Hardware error
Try removing the printhead (If removable) and clean the contacts on it, if it doesn't works there are no ways to fix this error
ADCSFXworks Printing Center <3
Nov 29, 2014 | HP PhotoSmart Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
I have a 3210 HP all-in-one printer and im getting the inksystem error 0xc18a0001 What should I do?
Apr 05, 2011 | HP Photosmart 3210 All-In-One InkJet...
MY hp c6280 says error 0xc18a0106. What does that
ME APARECE Error 0xc18a0001 que devo hacer para que se arregle mi impesora, saludos gracias
Jul 22, 2010 | HP C6280 All-in-One Printer
Ink system failure 0xc18a0001
Is the device still under warranty?
I hope so, because otherwise you are in the market for a new printer.
Ink feed system is faulty
Parts not available for these models
Dec 08, 2009 | HP Photosmart 3210 Printer
I receive an error when I try to print on my hp photosmart all-in-one printer. Ink system has failed. 0xc18a0001
Take the printer to a recycling-centre for responsible end-of-life disposal.
It's much more expensive to try to service it, rather than to replace it with a brand-new printer. Try to buy a new HP printer that uses the same ink-cartridges as you have in your current printer.
Nov 14, 2009 | HP Photosmart 3210 All-In-One InkJet...
Try this:
Oct 07, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
1,311 people viewed this question
Seeker5211
Seeker5211
