Question about Timex Sl Series Perpetual Calendar T2M506 Watch for Men
The instuction book that came with the Timex T2M506 I bought today, is not clear how to remove links from the bracelet
SOURCE: I want to change my Reef Gear bracelet of Timex watch!
I found another bracelet. Thank you.
Posted on Aug 27, 2008
indays
  • 111 Answers
SOURCE: timex data link band
good morning ! remove the spring bar carefuly to remove the band on your timex data link ! use screw driver to open the case back ! be verry careful to do that ! thanks !god bless !....
Posted on Sep 04, 2008
escapement
  • 2334 Answers
SOURCE: I have a bracelet link
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck
Posted on Dec 21, 2008
escapement
  • 2334 Answers
SOURCE: I need to remove a link from a solid link bracelet
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have the pins instead of screws.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 29, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
Posted on Aug 10, 2009
I bought the self adjustable bracelet watch but do not know how to adjust it to make it tighter on the wrist
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Aug 20, 2010 | Timex 2J611 Watch
My daughter bought a watch today and it does not have a set of directions on how to set the time, etc...
For all those who lost their Timex instruction manuals. Copy this link in to your browser and download manual for any Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads
Rate me, please.
Aug 01, 2010 | Timex Watches
Job done!
Aug 10, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Relic watchband that isn't the same as instuction book
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
Feb 15, 2009 | Relic 0504648FA
Need to shorten the band on a Timex Ironman Triathlon
These pins will definetely come out- poke a bit harder. You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Jan 04, 2009 | Timex Ironman Triathlon 50 Lap Digital...
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Feb 13, 2008 | Watches
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Timex Sl Series Perpetual Calendar T2M506 Watch for Men Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
