Question about Sony PMW-EX3 High Definition Camcorder
Th e Viewfinder image flips upside down erratically. Meaning as I rotate the viewfinder it is suppose to flip upside down as it rotates towards the subject being shot. But lately it'; s started flipping when not in that position. Also it has flipped without even moving the viewfinder. Any fixes?
    Genius:
  • 1,812 Answers
There is a switch in the LCD hinge mechanism that controls the image flip. It appears to be failing and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 15, 2010
My webcam on my Asus k501 is upside down. I use LifeFrame. How do I fix this problem?
If by upside down you mean that the image you see on the screen is inverted, then the settings of the webcam have been tampered with. When you launch your web cam, you would see the 'settings' option. Then select 'camera/image'. You would see the 'rotate' option. Rotate the image until it is erect. Also, if there is a 'flip' option, select flip vertically to make the image erect.
I hope that has fixed your problem?
Have a wonderful day.
Jun 23, 2011 | ASUS K50IJD2 Notebook
When I attempt to use my USB2.0 UVC VGA WebCam, the image that pops up is upside down.
There should be a setting in the camera software, that sets the mirroring or rotation of the image. Play around with the mirror-flipping options or the rotation factor to get the image right. If it's filpped upside down, a Flip Vertical should do, or a 180 degrees rotation.
If you find this post helpful and informative please vote with a Thumb Up. Thank you.
Jan 19, 2011 | ASUS K50IJ-C1 Notebook
Hello, We have a Canon 9080C with the latest release of Capture Perfect 3. Previously we have not had a problem but now, randomly, some pages are upside down. It is supposed to recognise a page...
I dont think the scanner can scan upside down. The image must be rotated after the scan. Any OCR software has confusion between 'L' & '7', S & 5, I & l (capital I and small L) and the OCR software rotates the drawing, based on initial perception. Just scan a set of Documents that were previously rotated while converting to PDF, as a JPG or TIFF file and check if the images are rotated.
S. Mohan
Sep 06, 2010 | Canon DR-9080C Path-Through Scanner
Viewfinder views things backwards
Yes, most finder scopes show upside down images, it's completely normal.
This is an astronomical telescope. Even the main tube shows upside down images unless you use what is called an "erecting prism" for terrestrial viewing.
Jul 06, 2010 | Meade 70AZ-TR Telescope
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Sep 20, 2007 | Hitachi PJTX100 Multimedia Projector
Lcd monitor and viewfinder not working when i try to record myself.
the flex wire of the lcd monitor is have a open line that why it is not functioning....there is also a switch to on the viewfinder connected to lcd....in some model even the lcd is damage you can still use the viewfinder...
Feb 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Sony PMW-EX3 High Definition Camcorder Logo
206 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
