Question about KitchenAid KERC607 Electric Kitchen Range
How long does the heat stay on to clean a oven
  • 567 Answers
To Self-Clean please follow the following steps.
1.Press CLEAN Press the number pads to set a clean time other than 3 hour 30 minutes. The clean time can be set between 2 hours 30 minutes and 4 hours 30 minutes.
2. Press START. The oven door will automatically lock and "DOOR LOCKED", the start time and stop time will appear on the oven display. The door will not unlock until the oven cools. When the cycle is complete and the oven cools, "End" will appear on the oven display and "DOOR LOCKED" will disappear.
3. Press any pad or open the oven door to clear the oven display.
This will resolve the issue you are facing. If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating
Posted on Sep 15, 2010
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
My electric Whirlpool oven won't heat after doing a self-cleaning.
It's possible the heating element burned in half while doing the self clean, it has to stay on a long time for the self clean cycle, try unplugging and plug it back in, might do it
Dec 06, 2014 | Whirlpool Ovens
My smeg oven light stays on the fan does not work and the oven does not heat up. This has happened straight after I took the door off to clean.
Yes, I have had the same problem. The light in the bottom oven stayed on and the oven did not work after taking off the oven door SOLUTION: I didn't put the oven doo back on properly. Take it off and try again!
Dec 08, 2010 | Smeg Ovens
Oven locks after self cleaning After self cleaning the panel indicates locked
I believe they can stay "Locked" for up to 3/4 Hours. See they heat up to like 900 Degrees, to "Clean" the oven... It stays locked until the oven "Thinks" it is "Safe" to be opened.
Feb 10, 2010 | Ovens
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
KitchenAid KERC607 Electric Kitchen Range Logo
48 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
